Changed Speedo Cable
Old Apr 9, 2008 | 08:40 PM
franks's Avatar
franks
Default Changed Speedo Cable
I Just Replaced My Lower Speedometer Cable For The Second Time .the First Time I Did Not Use The Grease And It Broke.this Time I Used The Grease But The Meter Is Reacting The Same Way,bouncing.is This Nomal When You First Install Them?
Old Apr 9, 2008 | 08:58 PM
blk79nj's Avatar
blk79nj
When you said lower cable, I assume that your car has cruise control. Whats probably bad is the cruise transducer.
When they ware out, it puts additional tension on the lower cable, until it breaks. There is a current thread about rebuilding them, or you can get a 'new' one from the regular vendors hear.
My car did this, I just put in a single cable.
Old Apr 9, 2008 | 09:24 PM
Glassbowtie77's Avatar
Glassbowtie77
Originally Posted by blk79nj
When you said lower cable, I assume that your car has cruise control. Whats probable bad is the cruise transducer.
When they ware out, it put additional tension on the lower cable, until it breaks. The is a current thread about rebuilding them, or you can get a 'new' one from the regular vendors hear.
I took out my complete cruise control system and replaced it with a single cable and it works perfectly. My is nowhere near stock so I'm not concerned with NCRS and I wouldn't use the cruise anyway. Less vacuum lines mean less vacuum related problems.
Old Apr 9, 2008 | 09:58 PM
franks's Avatar
franks
Default Big Thanks
Thanks Fellas,if It Breaks Again Thats What I Just May Do That,but Then No Cruise.
Old Apr 11, 2008 | 12:22 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
The cable can (in the housing )jump around making the spedo jump make sure the line is not jumping or moving . Tie strap it to the frame or something My 75 jumps every year or so I get out my spedo greasing tool give it A few pumps and away she goes for another year or so.
To Changed Speedo Cable
