'76 Tank / Sending unit Question.
Turned the key ... and ... well .. no ignition.
It rotates, no starting though. I added 2 gallons of gas (knowing that last year I had a minor tank leak toward the end of autumn,) tried again... nothing. I checked my haines manual, did the routine, pump the gas 2 dozen times, manually played with my choke etc. I noticed after even all of this, I didn't get my usual gas smell from my carb, so I pulled my gas line out, and saw it was bone dry.
Long story short (too late) I have convinced myself this is a problem with my fuel sending unit, however, if this is indeed the case, and knowing my tank had already previously had problems, I am wondering when I drop the tank if it would be possible to just put in a non-repro tank and sending unit without any major modifications or if I am forced to stretch the very limited college budget on a reproduction.
Any help or advice would be greatly appreciated, and thank you again for your time guys.
Most likely the fuel pump lost its prime over the winter (via evaporation), and needs some cranking/vacuum developed to get fule to the pump, and on to the carburetor.
Use quick start, or gas in the carb, to get it to fire, this will develop enough vacuum to pull the gas through the lines.
Definitely check your rotor, cap, and plugs, to ensure a hot spark.
Steve
Steve
GD - Fuses seem ok, The gauge moves, but I never look at my gauges as being even 25% accurate
This is my last resort (the sending unit and tank)Durango - wow, I neglected to check, I'll pull it tonight and see.
Halfmoon - I've tried some off the shelf carb starter (spray stuff, seems like it's almost like grill starter fluid) Cap, plugs and rotor should be alright. I'll try direct gas in the carb (have never done it before..) the fuel pump just might be it.
Either way, let me experiment tonight and get back to you all. Thank you very much though for the help guys regardless =). :o
btw, does anyone know offhand if it's ok to swap tanks and sending systems anyway (for future reference)
Try also attaching a long piece of fuel hose (3/8") to the engine end of the long steel fuel line from the tank, suck on it a few times while holding down near the ground, you should be able to get the fuel flowing out of the tank and through the lines, maybe a little gummed up at the tank or in the lines, but it should flow with a little persuasion.
Feel free to swap tanks and sending systems...a lot of work for components that don't seem to be involved.
Steve
Steve
Thanks for the help Steve
I'll be back tonight with updates and
for any further advice.
Brought it down to my mechanic, he had an electric pump laying around, we hooked it up .... it could pull nothing.
Ok, line of thinking NOW it IS my sending unit or something gumming up my tank itself.
But as I was talking to him, he sounded unsure of putting any 'ol tank up there. Said something along the lines of the tank and units being special made for the years ... is this really true? I thought the response was that anything could really go up there as long as it wasn't too big.
What say you corvette gods?
I have a feeling it's your pump. It's cheap and easy to install. Then if that doesn't work, drop the tank.
Now, something to consider, you'll likely be able to solve the problem by dropping the gas tank and evaluating everything you have. You'll be able to see if your lines are all still in good shape, if the bladder is okay, and if something is wrong or blocking fuel.
You'll have to buy all new rubber lines, S/S if you have the money, and just check out the actuation of the assembly in the tank.
What he said.
This filter in my car was blocked, so when the fuel pump was sucking hard on the fuel lines, it was drawing air into the pipe through weaknesses in the old perished rubber fuel lines after this filter.
Dropping the tank and checking the condition of these neglected pipes and filter will cost you nothing except some time and might save you all sorts of trouble. That's what I'd do, I think.
You can see into the tank with a torch (don't drop it
) so check the condition of the fuel pick-up sock visually too. Don't worry about the gauge/sender yet - it can't be the cause of the problem, as someone said above.
But in the US we call it a flashlight. Torch usually refers to something with fire here.You may have a clogged fuel line - if you have a leak there might very well be rust in the tank or lines or a rotted hose sucking in air, but you really need to get under the car and find out where the leak is coming from.
Rick B.
Thanks for the clarification. Will try to remember that one. We brits have a few weird ones to remember: What you call fenders, we call "wings". I have no idea why
And don't even get me started on tramp => bum => fanny => vagina
Paul, you hit the nail on the head, I added a ton more fuel cleaner, and dropped it off at my mechanic who worked his mumbo jumbo (using a funny looking snake with suction) and managed to get this sock gas permeable again.
Thank you everyone for all of your help again, every one of you did me a great deal of help by your suggestions. i hope in the future I am able to do the same
.I knew what he meant, but that could be VERY bad!!!
