I've been trying to find out some info on a 454 block, I just got my '69 shipped home a few months ago with a "NOM 427", and my casting number is 861959, I had to double check to make sure the first digit wasn't a three, but it's not...definitely an 8. I'm also curious to know where this engine originated, and if it has any value? Any help is welcome!
I and my casting number is 861959, I had to double check to make sure the first digit wasn't a three, but it's not...definitely an 8. I'm also curious to know where this engine originated, and if it has any value? Any help is welcome!
where is the pad located where you pulled the casting number from? Is there more than one pad on the block I should be looking for?
I cant read mine on the front of the block by the air conditioner compressor (73 convertible)
John in Dayton
Hi John, drivers side, rear of the block, just behind the cylinder head you'll find the casting number, the opposite side is the build date (if I'm not mistaken)
