ignition wire fuse?????
Old Apr 21, 2008 | 07:56 PM
rev'svette's Avatar
rev'svette
Default ignition wire fuse?????
where do I find the fuse for the ignition wire, before it reaches the coil? Thanks - kip
Old Apr 21, 2008 | 08:13 PM
Duke94's Avatar
Duke94
It's a fusible link and is the red wire that goes to the starter solenoid, then the yellow wire that comes off the starter solenoid goes to the coil
Old Apr 22, 2008 | 10:00 PM
RogieStone's Avatar
RogieStone
What year is your car if it is a h.e.i. car then you will have a fuse before the coil . The number 3 fuse I believe at least it is on a 77
To ignition wire fuse?????
