460 front springs
Old Apr 22, 2008 | 11:41 AM
72-454's Avatar
72-454
Default 460 front springs
I am in the process of changing my front springs. Bought 460 rate springs from Eckler´s. The original springs are about 2 inch longer than the new ones and have 2 more windings. Wire is same thickness and they seem stiffer when I try to compress them. Is that right? Will the front of the car be lower with the new springs which are shorter? I am asking because installing the springs for a try is no fun!
72-454
Old Apr 22, 2008 | 12:59 PM
Gordonm's Avatar
Gordonm
No it will not be lower. Chances are it will be higher. The 460s seem to sit higher. I just installed a set in another forum members car and had to cut a little more than 1/2 coil in order to get a correct ride height.
Old Apr 22, 2008 | 01:08 PM
rihwoods's Avatar
rihwoods
550's may drop it 1"....depends what your orignals are...
To 460 front springs
