Popping!!!!
Apr 23, 2008 | 10:07 PM
Popping!!!!
My engine is backfiring and popping when I take my foot off accelorator? I made it richer but still backfiring.
HELP? Is there a limit to how rich I can make it?
What else can it be?
Thank you!!!
Dino
More info:
75 l48 350 all stock exept edlbrock performer manifold with stock qjet and 2 1/2 inch true dual to twochambered flowmasters.
This just started happening, on deceleration. I made the carb richer with the dial on the passanger side of the carb.
Thanks DINO
Apr 23, 2008 | 11:08 PM
Is this happening at idle or when RPM’s are decelerating?
Apr 23, 2008 | 11:43 PM
Popping
Its popping or backfiring on deceration.
Apr 24, 2008 | 01:16 AM
I'd say you need to lean it down some. Popping is usually the burning off of unused fuel as it travels the length of the exhaust system. That's my two cent's anyway.
Apr 24, 2008 | 01:28 AM
Quote:
Dial on Passenger side of Carb
You talking about that big black one??
Thats the choke adjustment. Mixture screws are under the front of the carb. Enrichening the mixture screws will not solve your problem.
As asked prior is it popping back thru the carb or out the exhaust?
Apr 24, 2008 | 04:22 AM
Check for an exhaust leak.
Apr 24, 2008 | 05:48 AM
Is this stock motor or a motor with high compression? A motor with higher compression will do this.
Apr 24, 2008 | 07:47 AM
I had this problem in my 74 Camaro way back when... try increasing jet size. It cleared mine up nicely. Go up .02 at a time.
