Alternator pulley frustration- Help
Old Apr 25, 2008 | 07:47 AM
Mikeg72's Avatar
Mikeg72
Default Alternator pulley frustration- Help
I have a “69” 427 which I spent the winter converting to P/S & P/B.
The 1st. two V-belts off the crank (inside & P/S) line up perfectly. But the alternator belt (goes from the outside P/S pulley groove to the alternator) is off by ½” (needs ½” additional offset). I checked with paragon and they said I have the correct brackets etc.
I measured the offset needed from the alternator fan to the center of the pulley from the
P/S pump. I would need an alternator pulley with 1 - ¾” total offset (1/2” more than the Corvette 427 w P/S & P/B pulley has).
Should I be thinking about shimming the alternator outboard the ½”?
Or, looking at some other pulley? No one seems to know..
Suggestions?
Thanks,
Mike
Old Apr 25, 2008 | 08:04 AM
Ironcross's Avatar
Ironcross
I believe the correct alternator bracket is cast iron and bolts to the cylinder head on the left side. Is the alt on the left and the bracket cast? I would start there with the alt bracket as that is a certain constant as only one is correct..
Old Apr 25, 2008 | 09:34 AM
Mikeg72's Avatar
Mikeg72
The alternator is located on the driver side of the engine.
But, it's not a cast bracket. It's a welded steel bracket.
Mike
Old Apr 25, 2008 | 10:33 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Im sure you thought of this already but couldnt you use a Break bending machine (Big metal Bender )get the off set you need and shim the other end (a tube outside the bolt used as A spacer).It would almost look stock.You might be able to heat up the bracket now and just bend it,in A Big Vise.
Old Apr 25, 2008 | 10:59 AM
DARROW's Avatar
DARROW
My Pully Was Off About 1/2" And I Found A Pully At Parigon That Had A 1/2" Blank On The Motor Side Put The Belt Right On.
Old Apr 25, 2008 | 11:01 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Default Pulleys ??
please post your results with pictures if possible,
I am starting down the pulley road from a basketcase/parts and peices.
and I too must figure out what I need,
does anyone have a picture of the cast alternator bracket for a 69 ?
thanks, 69VETT
Old Apr 25, 2008 | 12:21 PM
DARROW's Avatar
DARROW
Default Alt Pully
Will This One Work?
Old Apr 25, 2008 | 02:16 PM
Mikeg72's Avatar
Mikeg72
Looks like you have the same pulley I have. Also got it through Paragon. But, it still needs another 1/2". I may resort to shimming the alt bracket but I think this will impact the P/S location and the braces. I'll have to take a look and get pics to display.. By the way, I believe the Cast alternator bracket is listed in catalogs as alternator w/ no P/S. If you go with P/S, you will need the welded bracket. See pg. 22 of the Paragon catalog.
Thanks,
Mike
To Alternator pulley frustration- Help
