Hood Cable
Old Apr 25, 2008 | 09:41 PM
pda1964's Avatar
pda1964
Default Hood Cable
Howdy Guys,
Had the cable between the latches break on a 78 and saw in the posts on the problem that GM still lists the cable. Anyone got the part number for the cable? Also, there are two springs on each latch, a spiral wound type and a bent wire type. Anyone know where I can find the bent wire one for the drivers side latch? Any help is appreciated!
Paul
Old Apr 26, 2008 | 09:07 AM
pda1964's Avatar
pda1964
Anyone???
Old Apr 26, 2008 | 09:23 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Why not just give the dealer a call for the p/n?
Old Apr 26, 2008 | 09:36 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Willcox and Zip-products has the cable. A search of "corvette hood latch" on e-bay turned up a few latches which would have the springs.
Old Apr 26, 2008 | 10:41 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
cable is available from numerous vendors, your choice for your price. The replacement cables come with a plastic tab that the small bolts hold to the firewall just before it goes into the latch. I have had the plastic tabs break off. Corvette America has a metal clamp that you can buy also that will replace the tab instead of having to buy a whole new cable. My last replacement cable lasted 3 months before it broke. I put the metal clamps on and its holding strong.
Old Apr 26, 2008 | 11:20 AM
Older Than Dirt's Avatar
Older Than Dirt
Get a GM one...
http://www.tld-corvette.com/prodinfo.asp?number=534823
To Hood Cable
