Rear diff fluid & additive
Old Apr 27, 2008 | 04:28 PM
bruced267's Avatar
bruced267
Default Rear diff fluid & additive
How much gear fluid and additive should I install in the rear diff. Also what brand is best? I just had my 3:55 installed, and well be installing hopefully next week sometime. Waiting on one more part. I post some pics of the install. TIA
Old Apr 27, 2008 | 04:38 PM
dmayhew's Avatar
dmayhew
The GM oil and additive is best in my openion
2 bottles of fluid and 1 bottle of addiitive
David
Old Apr 27, 2008 | 04:49 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I used Lucas 85-140 gear oil and two bottles of GM posi additive in mine when I changed it. Since yours is new you will probably need only the one bottle of pos additive. After you change it, go to a nearby parking lot and make a series of slow figure 8's to get it all mixed and lubed up.
Old Apr 27, 2008 | 05:42 PM
Carl Granquist's Avatar
Carl Granquist
Default rear differential "oil" change
I'm also getting ready to change this. Picked up the posi-additive yesterday at a Chevy dealership but haven't got the gear lube yet. LUCAS apparently has a synthetic, and while recommended I'm still looking for an "AC DELCO" product for the regular gear lube. "Schucks Auto Parts" doesn't carry it but I'm still looking. Maybe it doesn't matter too much? Others have mentioned that it's an easy procedure, but I only want to do it once plus there's no rush for me. 37 years since it's St. Louis birthday!
Let us know what you finally end up using.
File Type: pdf
Old Apr 27, 2008 | 09:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I used Mobil 1 that was a decent match for the specification and two bottles of the additive.
Old Apr 28, 2008 | 12:50 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Eaton "Strongly Recommends" the use of conventional lube with their posi units (installed on our Vetts).. Synthetics are too slippery and will decrease the effectiveness of your posi. This is from the Eaton page:
"What kind of oil should I use? Can I use synthetics? Do I need a friction additive/modifier?
Eaton Posi units perform best when using GL4 (or better) mineral/petroleum based gear oil. A four ounce bottle of friction additive/modifier is also necessary for optimum performance".
More here:
http://www.eaton.com/EatonCom/Produc.../FAQ/index.htm
Old Apr 28, 2008 | 08:53 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
GM posi lube along with whale oil (old school) if you can find it or today's synthetic additive. My diff. took 2 1/2 bottles plus the additive. At the dealer I paid 44.00 for the materials. Also to remove the plug I used an 5/8" 8 point socket. I was told to remove all the old fluid. Good luck WB
To Rear diff fluid & additive
