1980 One Owner
Well my dad ordered a 1980 corvette with split cloth leather, black ext, t-top, auto trans and the suspension package of the day. I was born in 1980, and this almost caused the cancellation of the order. There was already a 1971 corvette in the family that had been bought used (now my long term resto project)
Its a one owner car that has about 54-58k miles on it. Dad and I rebuilt the front end with poly bushings approx 9-10 years ago, I drove it for a while and when I went off to school my mom drove it. Not long after that my mother rear-ended a truck and somehow reeved the motor and we now believe it has a possible spun bearing, at least it seems to have a knock in the motor. It has sat since some in a barn until my parents sold the property and for a few years now in the garage of my mom's condo.
I know it will likely need a motor rebuild, new front clip, and headlight cover to get it back into shape. Paint and some other fixes too, obviously.
I am looking to get an esitmated value for the car as it sits.
I know photos would help, but the car is approx: 2 hours from my location right now so I would just like to get a general idea of its value at this point.
Anyone who has done a car like this knows that eventually everythingwill be replaced or rebuilt because it fails or is bleeding all over the place.
From there back the body panels are ok, could use new paint, but they are not broken or damaged.
"3 more characters to post this reply"
If you don't want to part it out, you might want to think about Frankenstein'ing it (ie; find another 80 with a good motor, no front-end damage, and who cares what the rest of it looks like and merge the two together).
Sit back with the cellphone and a pitcher of lemonade and watch the action!
JU
1st Market Value: How much can you actually sell the car for?
2nd Personal Value: How much is the car worth to you?
By the sounds of your posts the car holds a much greater value to you then it is actually worth on the market. If that is truly the case then don't worry about the market value of the car and the amount you spend fixing it. If it means that much to you you aren't doing it with the indent to sell so who really cares about dollars in vs dollars out.
Just make sure you insurance policy is and agreed upon value when you get it done.
To get it back to "really good" will take 8-10k and that is you being very careful and patient with what you buy for the car and doing all the work yourself. Remember, rebuild when you can; replace only what you must. Good luck.
Just to put some numbers to it: Ecklers OEM SMC front fenders= $300ea., Front top= $2k, Bumper Cover OEM= $500, Pieces behind the bumper (used) $250. Total=$3,350. Another $300 for paint. That might be all you'll need. You might not even need a whole front top piece, and you might also buy it used for less. You could also go cheap and buy a whole one-piece hand laminated front clip for $1,050. You could also find out you need inner fender panels and other parts. Hopefully you would be able to find them used for cheap.
Personally, I'd put all OEM SMC parts on it from Ecklers and it'll be as good as original and keep it's value. If you stick aftermarket hand laminated fiberglass on it, sure you're going to save some money up front, but you'll loose on the back side should you ever go to sell it. With the right stuff you'll fee a lot better about it too knowing it was done correctly, no compromises. In a few years, the 80 will be worth a few thou more and your investment up front won't seem so dramatic. Given it's age and mileage, the interior should be in really good shape. I bought Ecklers OEM SMC fenders and they are really nice. To me it's worth it to pay a little more for the right stuff.
