80 model rear window problems!
Old Apr 28, 2008 | 01:00 PM
corvettesroc's Avatar
corvettesroc
8th Gear
Default 80 model rear window problems!
I have an 80 model that has the back window that raises up. I need weatherstrip for it and haven't found what I'm needing. I also need to replace the package tray, but can't find one with the holes cut for the posts on the window. Help! I'm almost finished!
Old Apr 28, 2008 | 01:05 PM
rihwoods's Avatar
rihwoods
Try Dr Rebuild...found this:
http://www.docrebuild.com/dr-r-web/INDEX-W.HTML
I'd call them....they may have source...
Old Apr 28, 2008 | 01:15 PM
corvettesroc
8th Gear
Thanks! Will give them a try.
Old Apr 28, 2008 | 02:55 PM
tyancey00's Avatar
tyancey00
I did not know that you could get a window that raised up in back in 1980. I know about the 82, just not the 80. That may be the reason you are having trouble finding this for an 80, it was not an option.
Old Apr 28, 2008 | 03:31 PM
1982CorvetteDude's Avatar
1982CorvetteDude
It was an aftermarket "kit' that was available before 82. If I'm not mistaken GM contracted that "kit" for use on the 82 collector edition models.
Could someone verify this?
Old Apr 28, 2008 | 03:48 PM
corvettesroc
8th Gear
All I know is the VIN says its an 80, and the back window raises up. It also leaks! I will try looking at '82.
Thanks!
Old Apr 28, 2008 | 03:55 PM
Earthquake Driver's Avatar
Earthquake Driver
From: I buy all my days at the same place where the girl sells her nights
Was it Cars and Concepts if I remember right.
Old Apr 28, 2008 | 04:14 PM
Earthquake Driver
This car had a hatch http://www.vetteweb.com/features/vem...pe_turbos.html
Old Apr 28, 2008 | 08:57 PM
Fast81's Avatar
Fast81
Ecklers sold it -- they fit any 78-82 (non CE)
the weatherstrip you need is the 82CE weatherstrip. Corvette Central has it, maybe others.
Your lucky, this is a GREAT aftermarket add-on for any 78-82 IMHO
I'm modding FAST81 with this option also
Old Apr 28, 2008 | 11:10 PM
Red 69's Avatar
Red 69
My 79 has the hatch rear glass made by Cars and Concepts. When I bought the car the rear glass leaked and I first thought the weather seal was bad. It wasn't the case and it turned out to be rotted #4 body mounts. This may not be the case with your car, but take a look. The body on mine actually drooped as the frame bracket rusted under the rubber seal that rests on the frame bracket. This opened a gap between the glass and weather seal. On one side I needed to make a reinforcement to weld on top of the frame bracket and replace the body mounts. It wasn't all that difficult and all done with the body on. BTW...the 83 CE hatch glass weather seal isn't inexpensive.
Old Apr 28, 2008 | 11:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have the 82 ce rear hatch weatherstrip.
http://willcoxcorvette.com/product_i...ducts_id=16012
To 80 model rear window problems!
