Planning a trip to a couple of the local junk yards for odds and ends for the projects.
Any suggestions on which cars would have a temporary spare tire that would work on the 69?
My thoughts are to use a temp spare so I can store the jack and tools in the carrier since I've taken over the storage area with stereo equipment....
Also might see if I can snag a GM mini starter that would be a straight bolt in. Any ideas on which cars/trucks might have this (with the three lugs if possible - I'm lazy... ).
is it one of those small compact temporary spare tire you are thinking about? Would it not damage the limited slip differential (if you have one ofcourse) if you use one of these in the back?
Yes it would, so if you had a flat in the rear you need to chg two tires. Front to rear & mini spare up front. My .02 I wouldn't buy a used starter when new GM mini's are cheap enough from Napa.
Nope, not the compact "blow up" spare tire, but one of the tall thin deals that has the same height.
