Door Panel Question
Old May 3, 2008 | 08:33 PM
marines's Avatar
marines
Default Door Panel Question
I am planning to remove both door panels in order to replace the brushes that reduce rattling. After removal of the window winding handles, what can I expect? Thanks, Guys!:
Old May 3, 2008 | 09:37 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Not sure what year you have.
If pre '77 once the crank handles, door open handles and lock ***** are removed you just un screw the panel and it will come off.
If it is a '77-'82 you need to remove the door pull bezal and the arm rest. You will also need to remove the remote mirror lever and un plug the power lock if you want the panel completly away from the door. However if you are just replacing the anti rattle fuzzies then those may be left in place and the panel will set aside enough to do the job.
Any of the the years are fairly straight forward.
Old May 4, 2008 | 08:27 PM
marines's Avatar
marines
Thanks, I really appreciate your help!
To Door Panel Question
