Squeaky rear rotor :(
Old May 4, 2008 | 12:49 PM
AirTrafficController's Avatar
Default Squeaky rear rotor :(
I replaced the rear rotors on my Vette. I shimmed them, so runout isn't more than .002. It's more like .001, which is within spec.
The right rear rotor starts cyclically squeaking, especially after it's been driven a few miles. Do I have a dragging caliper? The calipers are 1 year old, O-ring style.
Heading off to O.C. Maryland in about 10 days and don't want to pull into town sounding like a washing machine...Thanks.
Old May 4, 2008 | 01:37 PM
Ironcross's Avatar
Ironcross
I would inspect tne U joint
Old May 4, 2008 | 01:52 PM
GD70's Avatar
GD70
Could possibly be the emergency brake pads rubbing slightly. How far do you need to pull the handle before they grab?
Old May 4, 2008 | 01:58 PM
U-joints are <2 yrs.old.
Parking brake - about 1/2-2/3 before it drags, and about 90% to lock them completely.
As I'm driving, if I depress the brake pedal, it stops.
Old May 4, 2008 | 02:05 PM
GD70's Avatar
GD70
Sounds like a brake pad. Rotor may be slightly warped and rubs the pad with each rotation, but disappears with brakes engaged.
Old May 4, 2008 | 03:11 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Hi Mark....hope you been doing well.
My 72 made a similar noise...UNTIL...pressure was applied to the pedal. It was annoying. I took that rotor and had it "turned". The shop said it was not warped, but it stopped the clicky clacky noise.
Fred
Old May 4, 2008 | 03:26 PM
rihwoods's Avatar
rihwoods
Could be brake pad build up on rotor....I just clean mine...Garnet paper is a good choice...
Old May 4, 2008 | 05:29 PM
stinger12's Avatar
stinger12
Could be brake pad glazing - when was the last time you replaced the pads
Old May 4, 2008 | 06:14 PM
I hate to have it turned, since I spent all that time shimming it to the hub. What is garnet paper? Is that like emery cloth? The pads are new with the calipers, less than 2 years old, less than 2k miles.
Maybe I'll try shimming it again and get it "perfect". Ugh.
Old May 4, 2008 | 06:38 PM
SteelCityBlue's Avatar
SteelCityBlue
Default same problem
Let me know what works please
To Squeaky rear rotor :(
