horn intallation
Old May 4, 2008 | 03:52 PM
gghg's Avatar
gghg
Default horn intallation
Hi Folks
I am trying to fix all the bad things from the previous owner(s). The car has only one horn installed and it is on the drivers side. I want to put the other horn in as well. Any one know exactly where it goes. The horn that is therenow is bolted to a welded nut on the front brace, can't find another welded nut for the other horn. Are the horns joined together somehow? I looked in the parts manual and shop manuals that I have, it just shows the horns not how they are mounted. If anyone has a pic or knows how they are hooked up that would be a help
Old May 4, 2008 | 05:04 PM
GD70's Avatar
GD70
They mount with one bolt each on the rear surface of the headlight support bar just below the front edge of the surround.
Old May 4, 2008 | 06:45 PM
72ls5fla's Avatar
72ls5fla
not all Vettes had 2 horns..
What year is your car?
Old May 4, 2008 | 07:19 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Need to know the year, my 78 only has one horn on the front. The other horn (alarm) is mounted in the inner fender well on the drivers side.
Old May 4, 2008 | 09:05 PM
gghg's Avatar
gghg
The car is a 69. The wiring harness has two connections for the horns. Mybe I'm assuming it should have two horns.
Old May 4, 2008 | 09:13 PM
champs65's Avatar
champs65
My 69 has 2 horns, they are mounted side by side underneath the front valence between the headlight doors.
Old May 4, 2008 | 09:38 PM
gghg's Avatar
gghg
Any chance of take a picture to see how they are mounted?
Old May 4, 2008 | 10:06 PM
champs65's Avatar
champs65
Tomorrow at work i'll take a pic
Old May 4, 2008 | 10:57 PM
65GGvert's Avatar
65GGvert
My 78 has two horns, one high and one low note mounted on the front by the headlamp vacuum cannister. One wire to each with a push on connector. The ground is made to the mounting bolt. It also has a horn in the fender well for the alarm.
Old May 5, 2008 | 06:44 AM
gghg's Avatar
gghg
Thats the way they are hooked up on mine but one was mounted with a bolt going through a welded nut and the other using a sheet metal screw. The welded may have fallen off, I looked but can't find any tell tale signs of the nut/weld marks.
To horn intallation
