Wiper Door Assembly Rebuild
Old May 4, 2008 | 08:41 PM
kaiserbud's Avatar
kaiserbud
Default Wiper Door Assembly Rebuild
I want to spruce up the assembly that raises the wiper door. WOuld like to at least paint it - I see those larger rivits keeping the plastic bushings... what's the advice on how to best paint and whether to do bushings? thanks
Old May 4, 2008 | 10:43 PM
BB72's Avatar
BB72
I actually bead blasted the whole linkage assembly with less pressure and painted with high heat black. I find that paint doesn't chip. Then once bolted in I worked WD40 into all the joints and it works great.
Old May 4, 2008 | 10:48 PM
kaiserbud's Avatar
kaiserbud
hmmm - so the blasting (must have been in the back yard?) did not damage the joint areas?
To Wiper Door Assembly Rebuild
