Bleeder screw seats
Old May 7, 2008 | 08:03 PM
seventysixvette's Avatar
seventysixvette
Default Bleeder screw seats
I'm rebuilding a set of calipers for the friend of a friend (side $), also doing the o ring conversion while they're apart.
The calipers are already stainless, but they've got some miles on them and the car is a driver, so I've been a while wire wheeling and bead blasting. The bleeders are out and getting replaced, but I've noticed some pitting and corrosion down around and on the bleeder seats.
Anyone know of a bleeder seat chamfering tool or something specifically made to clean bleeder seats up?
I just can't picture coating a Q tip with valve grinding compound and chucking it in a VS drill
Thanks fellers....
John
Old May 7, 2008 | 08:46 PM
noonie's Avatar
noonie
If you are really worried about it, you can turn the threads off an old bleeder and use the grinding compound on the end of it chucked in a small drill to lap the seat a little.
Personally, I just take the old bleeder and crank down a little harder on them and then put new bleeders in. Never had any leaks yet.
Old May 7, 2008 | 09:32 PM
seventysixvette
Might try the old bleeder screw suggestion if worse comes to worst.
If it was just me, I'd run the bleeders down tight and just go with it.
I tend to be a lot more cautious when working on someones elses car and accepting payment.
John
To Bleeder screw seats
