Gravity Feeding Brakes
Old May 10, 2008 | 12:24 PM
whiteflame's Avatar
whiteflame
Default Gravity Feeding Brakes
Put new calipers and pads on the 74 . What is the procedure on gravity feeding ( bleeding ) the air. How long does it take and what do i watch for too know when each bleeding is done ??? Can i do both bleeders on the back at the same time ??? Thnx Dave
Old May 10, 2008 | 01:50 PM
whiteflame's Avatar
whiteflame
No brake fluid coming out yet. Been about 45 min. Dave
Old May 10, 2008 | 02:23 PM
capecorvette's Avatar
capecorvette
it mat take an hour or more. i did mine like this and they work great
Old May 10, 2008 | 02:31 PM
whiteflame's Avatar
whiteflame
Pat , thnx for the reply. Did you do one bleeder at a time ?? Did you get a staedy stream coming out , or just drops. Thnx Dave
Old May 10, 2008 | 02:51 PM
champs65's Avatar
champs65
I did both sides at once and let it alone for several hours; just kept an eye on the reservoir. It made sense to me to jack the front up as well, but don't know if it is necessary or even matters.
Old May 10, 2008 | 02:54 PM
whiteflame's Avatar
whiteflame
Champs85, thnx for the reply. Will the fluid come out in a stream or just drops when it starts too run? Dave
Old May 10, 2008 | 08:09 PM
champs65's Avatar
champs65
Definitely not a stream---it will first get the caliper wet until enough moves to the bottom of the caliper and begins to drip to the floor, like a very slow leaking faucet.
There isn't much fluid weight in the reservoir to "push" all the way to the rear, so its a slow process.
Old May 10, 2008 | 08:25 PM
emccomas's Avatar
emccomas
Do you have the master cylinder lid off?
Old May 11, 2008 | 12:38 AM
whiteflame's Avatar
whiteflame
Got er dun fellas. All 4 brakes are done and working good. Thnx for the help. Dave
To Gravity Feeding Brakes
