Car Cover Recommendations
Old May 12, 2008 | 08:08 AM
DO2G's Avatar
DO2G
Default Car Cover Recommendations
Which car cover would you recommend for a 78 that is stored inside? I am looking for protection from dust and kids walking through the garage.
Old May 12, 2008 | 08:18 AM
wiseman79's Avatar
wiseman79
I've got a wolf, it's the best cover I've owned. It's about a year old and has no signs of wear, even at the spot I cut it to let the antenna pass through.
Old May 12, 2008 | 09:01 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
For indoor use only I use a Premium Flannel Cover from Corvette America.
Old May 12, 2008 | 09:51 AM
PETKAH's Avatar
PETKAH
For my 75 I have a MAX TECH from Corvette America -stored indoors. It came with storage bag, cable and lock. Suggest you do not cut a hole for the antenna - just unscrew top portion of antenna -if you can-and put in car.
Old May 12, 2008 | 10:54 AM
DO2G's Avatar
DO2G
Which Wolfe did you get?
Old May 12, 2008 | 12:50 PM
Crash80's Avatar
Crash80
I spent a whopping $29.00 for one at Costco a couple of years ago. It looks to be made just like all the 4 layer car covers I have seen out there....and my car is outside. Works like a charm and cheap, just like I like them.
Old May 12, 2008 | 03:50 PM
wiseman79's Avatar
wiseman79
I'll check it out when I get home, I'm even fuzzy on where I got it.
Old May 12, 2008 | 09:34 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
if you value your paint do not use a cover. all it takes is one grain of sand on the car or under the cover as you pull it on and you will damage the finish. just wash it often for dust and scare the hell out of the kids if they get near it
Old May 12, 2008 | 10:03 PM
SmokinBBC's Avatar
SmokinBBC
Originally Posted by 2000FRCZ19
if you value your paint do not use a cover. all it takes is one grain of sand on the car or under the cover as you pull it on and you will damage the finish. just wash it often for dust and scare the hell out of the kids it they get near it
and the friggin cat
The California Duster works well.
Old May 12, 2008 | 10:06 PM
DO2G's Avatar
DO2G
Good idea...
To Car Cover Recommendations
