metal cutter
Old May 19, 2008 | 11:57 AM
rajsid's Avatar
rajsid
Default metal cutter
I am looking for a metal cutter for removing the old exhaust from my car. What tool do you use for this?
Will a receprocation saw work? if yes, what kind?
I spent 4 hours this weekend trying to pull out the old pipes without damaging them. Looks like I may have to cut it off.
Old May 19, 2008 | 12:34 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
sawzall with blades for meta
works every time
Old May 19, 2008 | 12:35 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
If its for a one time use a reciprocating saw is kind of expensive but its quick and easy with it, plus it can have all kinds of other uses around the house/shop . I have both plug in and cordless. Dewalt makes a good cordless, whatever brand you get I would get at least an 18 volt minimum if you go cordless. Plus some bi- metal 6 or 8 inch blades and go to cutting!
Old May 19, 2008 | 12:41 PM
markdtn's Avatar
markdtn
Recip saw or hot wrench (acetylene torch). You could use a chain type pipe cutter, but I imagine they are expensive and would have limited use.
Old May 19, 2008 | 01:37 PM
rajsid's Avatar
rajsid
Thanks all,
I think I am going to buy a corded reciprocating saw.
Old May 19, 2008 | 03:34 PM
Hvymtlc5's Avatar
Hvymtlc5
20.00 at harbor freight or cummings tools...will work well for occassional metal cutting.....
Old May 19, 2008 | 03:55 PM
75 Red Vert's Avatar
75 Red Vert
But get some good blades, the ones that come in the Harbor Freight ones are junk.
Old May 19, 2008 | 04:06 PM
Gordonm's Avatar
Gordonm
Quality blades will make the job a piece of cake. I am a little biased but use Lenox blades. I have worked for them for 22 years and have yet to see a better blade. Here is just a small sampling of some of the recip blades. A 618R or 624R will make short work of exhaust pipes.
http://www.lenoxtools.com/enUS/Produ...IP_BLADES.html
Old May 19, 2008 | 09:21 PM
rajsid's Avatar
rajsid
Does anyone one any of these?
I am thinking of just buying one from the local Home Depot.
$50-100 range
$100-150 range
Old May 19, 2008 | 10:05 PM
tmacb's Avatar
tmacb
If you are only going to use it occasionally, the Harbor freight reciprocating saw is actually pretty decent. I agree about the blades though. Invest in something of better quality. The Milwaukee blades work extremely well. The "torch" bimetal blades cut better than anything else I have used. They will make quick work of your exhaust project no matter what saw they are in.
Old May 19, 2008 | 10:17 PM
glassman74's Avatar
glassman74
I have one and works fine. Get good blades.18 or 24 tooth work best
on thin wall tubing. glassman74
Old May 20, 2008 | 12:51 AM
chvet73's Avatar
chvet73
Sawzall and bimetal blade. Better than a torch, which in tight quarters always scares me.
To metal cutter
