Broken Speedometer Needle; Repairable?
) looked down to check speed and the needle was gone. When I got back to the house and had a closer look, needle is at the bottom of the gauge. I looked in the archives and didn't find much on the subject. Anyone know how difficult it is to repair this problem, hoping that I don't have to buy a new $300 speedo. Any advice is appreciated.
Rick B.
I bought an NOS one, just haven't had the time to get into............good excuse for the Troopers though,
Really sir, my speedometer must be broken!!!
You don't have to press much and you won't likely feel it set into place so don't keep pushing expecting it to click or anything.
cc
cc
it is possible it could be so stuck that you need those, but try pulling with your fingers while twisting counter clock wise first. it should come right off that way.
if the needle were extremely stuck to the shaft and you tried to twist it too hard, you could possible damage or break the shaft, but if it's that stuck something’s probably going to break anyway.
You can remove the needle via either method posted above. It's my personal experience in rebuilding a speedo that the "twist counter clockwise" method adds risk as you must put pressure on the tiny hub with you fingers while twisting and if you're not careful you can damage/bend the needle should your fingers slip (not that it's a issue with your current needle). Additionally there is the unnecessary risk of possible damage to the calibration spring. GM had/has a tool specifically for pulling up and removing the needles. Short of having that tool laying around a fork works remarkably well. Whatever you do don't pry against the faceplate as it is quite delicate nor should the painted numbers be touched. There is a forum member who used to perform this service for GM who posted photos of the tool but the post of the photos are no longer available. Wilcox also has a very nice writeup on speedo rebuild which describes their method of "twist and pull". Choose your poison.
http://willcoxcorvette.com/repairand...lp.php?hID=145
I did not have time to read all the post, but if the needle is off the speedometer, the speed cup is probably broken.
I'll have time later tonight to read this and see. I"m sorry, I have a date with my wife tonight.
Willcox Inc.
To answer some of your questions about this quickly here I go!
1) To install a needle on a 1953-1977 W series speedometer you should gently push the needle on the speed cup shaft that extends from the face. When you place the needle on the shaft do it loosely at the 2 o’clock position. Once you have it on the shaft you should turn it counter clock wise while pushing inward on the center of the needle. Push and turn the needle until you pass the zero mark on the speedometer by about 1/8”. When you release the needle it should be on zero and locked in position.
If you do not land on Zero and want to try again, keep turning the needle counter clock wise while pulling outward. This will remove the needle from the gauge again. Start over and try it again. The tension spring on a W series speedometer will not stretch or be hurt by going counter clock wise since the speed cup has a stop arm built in to it that will catch and not allow the spring to be un-wound.
2) Needles typically don’t come off gauges unless there is a problem. If the entire needle falls of, there is a good chance the shaft that it is applied to is broken off inside the needle. If the speed cup shaft is not broken off in the needle, there still may be a problem. I suggest you read our help section on the speedometer/odometer for better details until we get the new help up on these separate issues. These symptoms are related and there is great info on the other page that will help you understand the parts that make the speedometer work. Simply installing the needle back on the speedometer and installing it in the car may only be a temporary fix which will end up costing you more money in the long run if the speed cup shaft breaks.
3) If the long end of the needle broke off the speedometer, this is usually caused by the needle being slammed from direct contact with the first worm and magnet. I again suggest you read the help section mentioned above as to the cause of this. Installing a new needle on the gauge in most cases will only result in another broke needle.
Summation:
I most cases needles that come of are an indication that the unit needs repair. Plain and simply put, something caused the needle to come off! I will try to explain all the causes in detail on our new help page when it’s up. The time and effort involved in removing the speedometer and for the record, tachometer (in 74 and prior cars) is not easy and installing one that is in need of repair will only cause you to remove the pad twice, and spend money down the road you do not need to spend.
You may direct emails on this as well as any input to our customer service email address at Willcoxcustomerservice@willcoxcorvette.c om
Willcox Inc.
