window tint removal
Old May 20, 2008 | 01:02 AM
cscaffidi's Avatar
cscaffidi
Default window tint removal
my 80 has the rear window tinted but it has hundreds of tiny bubbles all over the place. does anyone know the best way to remove the tint or get rid of the bubbles without damaging the defroster lines?
Old May 20, 2008 | 06:37 AM
VeroL81's Avatar
VeroL81
I have the same problem - no bubbles, but it's starting to turn purple. Old/poor tint I guess.
I'm tempted to take a razor blade and have at it - along with the defrost wires (half of them don't work anyway).
How 'bout it guys? Maybe a heat gun?
...Alan K.
Old May 20, 2008 | 07:34 AM
corvette-pilot's Avatar
corvette-pilot
Oooopppsss, got hit with a rock and broke, call insurance and have it replaced
Old May 20, 2008 | 08:05 AM
Durango_Boy's Avatar
Durango_Boy
Don't razor blade the stuff out...you'll not only make the job harder but you'll spend a lot of time scrubbing adhesive off the windows.
You'll need a heat gun, a bottle of light adhesive solvent, and some thin plastic scrapers.
Start at the top, and work your way down. Go slow, and don't peel or scrap down unless the area has been heated up and some solvent sprayed on it.
Old May 20, 2008 | 08:41 AM
VeroL81's Avatar
VeroL81
Re heat gun - I really think the closer I come to the outer seals the higher the probability of those seals MELTING!
Has anybody actually done this??
...Alan K
Old May 20, 2008 | 08:43 AM
Durango_Boy
...Alan K
Just keep the heat low. Don't go crazy, hold the gun further away. The rubber of the weather stripping can handle a little bit of heat, so just be careful.
Old May 20, 2008 | 09:35 AM
Glassbowtie77's Avatar
Glassbowtie77
Here you go. http://www.tintdude.com/remove.html
Old May 20, 2008 | 10:04 AM
VeroL81's Avatar
VeroL81
supervette77,
Good site - thanks! As soon as I finish this complete kitchen renovation I've got going I'll give it a try!
July should be prime time for the Florida sun to heat the tint!
...Alan K
Old May 20, 2008 | 12:49 PM
killain's Avatar
killain
Oldtimer
The local tint shop uses a mix of ammonia and water in a spray bottle and she/he uses a plastic scraper to remove the tint a few minutes after spraying the glass. I wouldn't use a steel scraper as most of the back windows have a defroster element laminated to the glass and you'll destroy it useing a metal blade.
Old May 20, 2008 | 01:18 PM
RagTop69's Avatar
RagTop69
Lose the heat gun. Use a high wattage hair dryer. It won't melt anything. Heat the window from the outside and begin removing the tint by getting an edge up. You can remove any remaining adhesive with Goo Gone.
Old May 20, 2008 | 01:39 PM
pbcanney's Avatar
pbcanney
I razor bladed mine (using windex as a helping agent)
kiss your defrost goodbye though
VeroL81's Avatar
VeroL81
Well, it seems we have "hair dryer" vs "ammonia"!
I've a solution. Since the door tint also needs to go, as well as the rear bubble window tint, I'll do each door using each proceedure.
I'll report back in a couple of months and let the group know which worked better!
...Alan K
Old May 20, 2008 | 01:44 PM
Durango_Boy
Not really a VS thing, you use both. The heat helps to soften both the tint and the adhesive, and the solvent, as specified as water and ammonia or something like Goof-Off, will help break the hold of the adhesive as you scrape it off with a plastic scraper.
Old May 20, 2008 | 01:46 PM
halfmoontrail's Avatar
halfmoontrail
I had the purple problem on my '74 coupe, was so concerned about it, I started taking the windows out of my parts car...
Then, I got an edge up with my fingernail, and the tint on each window came off easily, in one piece!
I probably have some cleanup with GooGone on adhesive, but the removal was far easier than I had feared.
Steve
Old May 20, 2008 | 02:36 PM
crossfire1982's Avatar
crossfire1982
I had mine removed by a local tint shop some time back. They steamed it off with a steam wand. Did a great job and NO damage.
Old May 20, 2008 | 06:15 PM
killain's Avatar
killain
Oldtimer
Durango boy has the best advice, using the ammonia and some mild heat will work swell too, we're just trying to help you save the glass. Any metal blade is going to damage the glass. It's like ice scrappers, get a scrapper with a brass blade, or plastic. They do a good job and you don't have to take a chance of scraching the glass.
Old May 20, 2008 | 06:58 PM
Bow-Tie Guy's Avatar
Bow-Tie Guy
I had the same problem with my '81. The tint started bubbling up and really looking bad. I used Simple Green, a black plastic garbage bag, a razor, and good 'ole fashion sunlight.
First, I waited for a sunny day. Then, I cut open the black garbage bag and taped most of the rear window from the inside. Next, I sprayed the window interior with the Simple Green (an ammonia/water mixture works too) and saturated the tint.
I waited about an hour for the sunlight to "heat up" the Simple Green solution on glass. Remember to apply the solution periodically to keep the glass/tint wet all the time.
Finally, I used the razor to start a corner and began to peel carefully. The secret, I learned, was to make sure to keep the tint material wet with the heated solution. This makes the tint material soft again. Otherwise, the tint film will actually separate from the adhesive material on the glass when you go to peel it off.
I got lazy and didn't continually re-apply the solution, so some sections dried out and hardened again...
To window tint removal
