Turn Signal Lever?
Old May 20, 2008 | 09:42 PM
Sweetaction's Avatar
Sweetaction
Default Turn Signal Lever?
I was just wondering if anyone knew how to install a turn signal lever for a 79 and could give me some tips on how to go about doing it? Thanks
Old May 20, 2008 | 09:47 PM
Hogwild's Avatar
Hogwild
do you have the tools to remove the hub and a shop manual.?
ntq
Old May 20, 2008 | 09:57 PM
vettecrazy88's Avatar
vettecrazy88
Look for posts by Jim Shea. All you need to know will be there.
Old May 20, 2008 | 11:36 PM
Jim Shea's Avatar
Jim Shea
The 1979 C3 turn signal lever just "plugs" into the plastic dimmer pivot. The pivot has a spring loaded ball that holds the lever in place. Just push it straight in.
Jim
Old May 21, 2008 | 08:29 AM
Sweetaction
Jim
How do you take the old one out? Does it just unscrew? Thanks
Old May 21, 2008 | 09:40 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
http://jimshea.corvettefaq.com/?page_id=4
Old May 21, 2008 | 12:12 PM
C3 4ME's Avatar
C3 4ME
Old one just pulls out. It's not easy, but it will come out. I learned this from here on the forum after disassembling my column to remove the lever only to find out I didn't have to.
Old May 21, 2008 | 02:23 PM
Jim Shea's Avatar
Jim Shea
If you install it by pushing it straight into the dimmer pivot, you can remove it by pulling straight out.
Jim
Old May 21, 2008 | 11:31 PM
Sweetaction
Thanks for the help guys, it turned out well.
Old May 22, 2008 | 08:55 AM
worship79's Avatar
worship79
Was your lever with cruise or not?
Old May 22, 2008 | 11:40 AM
Sweetaction
The original lever that broke had cruise control on it, but i just decided to replace it with the one without cruise because it cost a lot less and i didnt really care to have cruise control.
To Turn Signal Lever?
