Tire size combo?
Old May 21, 2008 | 07:02 AM
RunningMan373's Avatar
RunningMan373
Default Tire size combo?
What do you think of 235/60/15 front and 255/60/15 rear- any potential problems mixing the two sizes?
Old May 21, 2008 | 07:16 AM
Bangkok Dean's Avatar
Bangkok Dean
There are many running that combo with no problems. I am running 255/60/15 on all fours no problem but I have an 81 and understand the early C3s have clearance problems on the fronts with 255.
Old May 21, 2008 | 10:34 AM
Jims79's Avatar
Jims79
you can run the 235/60's front & 255/60's rear. I have 245/60's front & 255/60's rear. my .02 I think the 235/60's look too small and do not fill in the wheel well.
If your thinking tire rub on the inner fender you can run 225/70's front & 255/60's rear..........That way the side wall will be the same height.
Old May 21, 2008 | 10:45 AM
Jaybird907's Avatar
Jaybird907
I have 240/40/18 on the front and 275/40/18 on the rear.
Old May 21, 2008 | 02:32 PM
outlawkinser's Avatar
outlawkinser
I've been running 235/60/15 front and 255/60/15 rear for about 10 years with no problems. I'm using 8.5" wide rims and it's on a '74 and I had rubbing problems with the 255's on the front. Went to the 235's for the clearance.
Old May 21, 2008 | 09:59 PM
den(thevetteman)78's Avatar
den(thevetteman)78
I have 255/60/15 at the back and 235/60/15 in front on my '78 for the last 15 years and never had any problem. The only thing i did was raising the back just a bit to have the same gap between the tire and fenders.
Old May 21, 2008 | 10:12 PM
rydoc's Avatar
rydoc
I`m running Bf Goodrich Radial TA`s 245/60/15 front
255/60/15 on the rear ...no rubbing no problem on my "73"
Old May 22, 2008 | 11:24 AM
justaguy10825's Avatar
justaguy10825
235/6015 On Front & 275/6015 On Rear... No Rubbing Issues At All On My 78 & Looks Great...
To Tire size combo?
