I have a 73 coupe the drivers side rear says 3970010 the front passenger side says V0926cla and the vin number the rear date I believe says I232 which is Sep 23 1972 the blue build sticker in the door says october 1972 can someone please tell me this makes sence I have number 4,381 vette of the assembly line I just wanted to make sure that these dates could be in a 1973 because someone told me the rear date should have a 3 at the end and I told them no that number does not represent the year of the car it's the engine build date.
3970010 = casting number 350ci
I232 = casting date of September 23, 1972 (calendar year date)
V0926CLA = Flint September 26, 1972 engine build date
CLA = 1973 350ci/190hp with turbo400 transmission
04381 = serial number - approximate build date Tue Oct 10, 1972
your numbers line up just fine. You can confirm your build date on the trim tag - it will show C09 or C10.
