Paint Codes Question
Old May 30, 2008 | 10:09 PM
70Yellowbird's Avatar
70Yellowbird
Default Paint Codes Question
I just read through the thread on the 'Most Desired 68-69 Color' and noticed a post with a vote for Safari Yellow. I wondered what the paint code # was for that color, so I went to the Corvette History Website which indicated the # to be 984 for a '68.
http://100megsfree4.com/corvette/
My '70 is Daytona Yellow, also with #984 ... is this correct ... two different years, two different colors, same paint code #?
Or, are they both really the same color with different names?
Or, is the Corvette History database incorrect?
Anybody know?
Old May 30, 2008 | 10:37 PM
RobRace10's Avatar
RobRace10
Corvette Black book show the same info as you said #984 was Safari Yellow in 68 and #984 is Daytona Yellow in 69 and 70. Not sure if it is the exact same color.
Old May 31, 2008 | 12:13 AM
Daves76's Avatar
Daves76
They are exactly the same color. Paint is identified by it's code number, not the name. They just change the name around to use it on different cars to save $.
Dave
Old May 31, 2008 | 01:11 AM
70Yellowbird
Thanks for the help ... I also just found #984 for both '66 and '67 - Sunfire Yellow!
I'll look for more when I have time.
Old May 31, 2008 | 09:07 AM
Daves76's Avatar
Daves76
Not a problem I have not been on here long but it feels good to help out when I can.
Dave
Old May 31, 2008 | 10:25 AM
Tom73's Avatar
Tom73
Dave
The codes may be the same but I am not sure they are the same color.
For 68 the 984 Safari yellow used Lucite #4906-L, or Rinshed-Mason #A-2009, or Ditzler #81621.
For 70 the Daytona Yellow used Lucite #5026-LH, or Rinshed-Mason #A-1802, or Ditzler #2094. These are the same numbers as for the 69 Daytona Yellow.
So I would assume that 69 and 70 are the same but the 68 is different.
Numbers from the GM Corvette Chassis and Body Parts Catalog.
Old May 31, 2008 | 10:53 AM
70Yellowbird
That's great info ... sounds like when I order paint, I should tell them the paint code # and the year of the car ... I guess!
Old May 31, 2008 | 11:51 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
If your car has origional paint on the door jams or anywhere else it's best to let the store match that color. A lot of the new paint dose not match the old lacquer paint color. Yellow is one of the easier ones to matcht though.
KEN
Old May 31, 2008 | 12:29 PM
Tom73's Avatar
Tom73
KEN
Good point. Those old paints are lacquer and in some areas you cannot get or us that anymore. So you end up with a basecoat/clearcoat paint. The paint store should be able to tell you what is close to the old lacquer.
tom...
Old May 31, 2008 | 11:21 PM
dbeall1968's Avatar
dbeall1968
Tom73 is correct. The 69 Daytona yellow was a much brighter color than the 68 safari yellow. 68 was more cream/pale yellow, even though the codes are the same. I do believe that the 66-67 yellow was the same as the 68. They are sure close. A real purist can tell Daytona from Safari from a mile away.
To Paint Codes Question
