control arm/ caliper bracket torq specs
Old May 31, 2008 | 09:51 AM
Andy&Kelly's Avatar
Andy&Kelly
Default control arm/ caliper bracket torq specs
Hi All
Im trying to find the torq specs for the upper and lower control arm shaft bolts (bushing ends). I replaced the rubber with poly, but cant find the specs for them.
Also, looking for the upper caliper mount bolt torq spec, the big one at the top of the spindle on the front
Thanks,
Andy
1968 corvette L79
Old May 31, 2008 | 09:25 PM
TimAT's Avatar
TimAT
My memory sucks, but I think 50 ft/lb on the control arm shafts WITH red locktite, and something like 130 on that big bolt on the spindle. Be sure and get verification!!
Old May 31, 2008 | 09:48 PM
Glassbowtie77's Avatar
Glassbowtie77
http://www.vbandp.com/instructions/torque%20specs.pdf
Old Jun 1, 2008 | 02:43 AM
saudivette's Avatar
saudivette
Originally Posted by Andy&Kelly
Hi All
Im trying to find the torq specs for the upper and lower control arm shaft bolts (bushing ends). I replaced the rubber with poly, but cant find the specs for them...
Yes Tim, you're right. Shop manual says 50ft/lbs for the control arm cross shaft bolts
Also, looking for the upper caliper mount bolt torq spec, the big one at the top of the spindle on the front...
Not sure what you mean here. Both brake caliper mounting bolts in my (82) shop manual are 70ft/lbs
Old Jun 1, 2008 | 10:04 AM
Andy&Kelly's Avatar
Andy&Kelly
Thanks guys
To control arm/ caliper bracket torq specs
