Stainless Trim Rings
Old Jun 1, 2008 | 05:10 AM
whiteflame's Avatar
whiteflame
Default Stainless Trim Rings
Any tips on the best way to clean up a set of 1974 Ralley wheel stainless trim rings. Rings are in very good shape as far as no dings ( some scratches ) but need a good cleaning . Thnx Dave
Old Jun 1, 2008 | 05:46 AM
marshrat99's Avatar
marshrat99
I'd first try some Neverdull. If it doesn't cut too good then go to 400 grit sand paper. It that don't do it then try 220 grit then up to 400 and then Neverdull.
Old Jun 1, 2008 | 06:01 AM
whiteflame's Avatar
whiteflame
Ok will give it a shot Thnx Dave
Old Jun 1, 2008 | 07:27 AM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
acid for removed an oxidized surface cleans them great
Old Jun 1, 2008 | 07:58 AM
R1234's Avatar
R1234
I start with the least aggressive polishing compound and work my way up.
Bryan
Old Jun 1, 2008 | 08:02 AM
whiteflame's Avatar
whiteflame
What kind of Acid ?? Thnx Dave
Old Jun 1, 2008 | 08:24 AM
400hp427vette
St. Jude Donor '09
phosphoric, nitric, citric, or oxalic acid, there are many wheel cleaning products with these acids in them. white lightning wheel cleaner sold at walmart is the one I use
Old Jun 1, 2008 | 09:23 AM
Glassbowtie77's Avatar
Glassbowtie77
Here's what I use and it works really well. http://www.amazon.com/Mothers-Mag-Al.../dp/B0008D6NDM
Old Jun 1, 2008 | 10:59 AM
70Yellowbird's Avatar
70Yellowbird
Wad up some aluminum foil and wet it w/ water. Add elbow grease. You might be pleasantly surprised on how well it works on ss and chrome. Please let me know if you try it. Good luck.
Old Jun 1, 2008 | 11:15 AM
whiteflame's Avatar
whiteflame
Thnx for all the good tips fellas. Will keep you informed. Thnx Dave
To Stainless Trim Rings
