Brake lockup?
Old Jun 1, 2008 | 01:08 PM
Skyhigh82's Avatar
Skyhigh82
Default Brake lockup?
Driving my 82 the other day when I got cut off, hit the brakes and my lt. rear locked up. Is there a way to get them to work evenly?
Old Jun 1, 2008 | 03:14 PM
Durango_Boy's Avatar
Durango_Boy
Check the flex hose on that wheel. The hose can separate between layers, and swell, causing it to lock the fluid int he caliper. You can check for this by jacking the rear up, and trying to turn the wheel by hand. If it's hard, loosen the bleeder to release some pressure, and then tighten it, and try to turn the wheel.
If it's easier after pressure was bled then you will want to replace the flex lines.
If it doesn't make it any easier, you may have a mechanical seizure of some kind and I suggest removing the pads and caliper and checking to see if the wheel turns.
Old Jun 1, 2008 | 11:24 PM
Blue Seducer's Avatar
Blue Seducer
Happened to me. A new hose fixed it.
To Brake lockup?
