1977 L-82
Old Jun 3, 2008 | 04:08 PM
Quani's Avatar
Quani
Default 1977 L-82
I have a 1977 L-82 4-speed. The Vin has an 'X' in it to verify . my question is, what numbers do i check to make sure that it is the original engine and trans? And, where do i find those numbers? I know nothing about cars so details will surely help. Thanks guys, gary
Old Jun 3, 2008 | 04:14 PM
Binnie77's Avatar
Binnie77
The engine number is stamped on the block just ahead of the right cylinder head. The last 5 digits on the block should match the last five of your VIN number if it is the original engine.
Old Jun 3, 2008 | 06:17 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
You should also find the last 8 (i think) of the VIN stamped on the tranny. Can't remember exactly where...
Old Jun 4, 2008 | 07:44 AM
??????'s Avatar
I can not find the area where everyone is saying that the last 5 of the VIN # is stamped on the block. I do see a flat part of the blosk just ahead of the right valve cover.
This is, I believe, the casting number off of my engine. The only thing I can guess is that my engine is not original since I can find no numbers stamped into the block on the front.
Grant
Old Jun 4, 2008 | 07:56 AM
RunningMan373's Avatar
RunningMan373
Passengers side, on engine block shelf, right below and in front of the head. A/C compressor can make it hard to see, but it's there.
silver part is part of the water pump, large stamp is the engine #, small last 5 match the last 5 of the Vin, if it's a #'s matcher.
Old Jun 4, 2008 | 11:28 PM
jrl77's Avatar
jrl77
Default AHHH there it is !
Although I did not ask the quest. with your pic. & help I found mine !
She is the orig. eng. L82, And this goes for the tran's.,rear as well .
Thank you
JRL77
Old Jun 6, 2008 | 12:40 PM
Quani's Avatar
Quani
I must be BLIND! I still can't find it. What other tips can you give me? Where is the cylinder head? I know it's in front of that according to a previous post. Thanks for the help and Patience.
Old Jun 6, 2008 | 01:05 PM
C3 4ME's Avatar
C3 4ME
The trans # will be on the passenger side up high on a flat surface. It too should have the last digits of your VIN stamped on it.
Old Jun 6, 2008 | 02:11 PM
MakoShark77
Ah, oh, dude.
Its possible that it doesn't have the original engine or someone has done some engine work on this one and removed the numbers. The cylinder heads are on each side of the engine and are easily id'ed by the valve covers. In front of the passenger side head look for a small flat rectangular area. That is the pad where your numbers should be stamped. Its not very big, maybe 1 x 2 inches, and it's very possible for this area to be covered in grime and you may have to clean it off to see your numbers. May even need a wire brush. If you see the pad, but no numbers, it could be that the engine was worked on previously and the block had to be "decked" to ensure it was flat and mated with the cylinder head properly. Sometimes, in this process, the numbers are accidently removed.
Old Jun 6, 2008 | 06:17 PM
RunningMan373
Down in front.
Old Jun 6, 2008 | 07:09 PM
Quani's Avatar
Quani
The air cond. components are blocking my view. There is a bracket that shields the front of the head. Am I getting close? I know, I know. I will go play in traffic once I finally locate this @#$% thing. I hope my car never breaks or I'm in serious trouble!!!
To 1977 L-82
