Hood insulation installation
Old Jun 10, 2008 | 02:28 PM
77vetter's Avatar
77vetter
Default Hood insulation installation
I am wanting to replace my hood insulation - it is really ratty looking. I was wondering how those plastic clips that hold it place work. Are they reusable or do I have to order new ones as well? Is it possible to remove them without wrecking them and if so how do you do it?
Old Jun 10, 2008 | 02:59 PM
PETKAH's Avatar
PETKAH
On my '75 the pin is attached to the underside of the hood and it is made of plastic - the retainer pushes on and off when you squeeze the top part of the pin. I have 11 pins but for a '77 you should have 8.
Search vendors for -- Hood Insulator Mat with pins and retainer.
I painted the metal retainers silver, and the mat sprayed black. (OK, does it really absorb any sound?) Or buy the mat/pins for about $40.
Old Jun 10, 2008 | 03:03 PM
Scottys78's Avatar
Scottys78
I need to do this too
Old Jun 10, 2008 | 03:11 PM
77vetter's Avatar
77vetter
Thanks for the info! I am assuming the retainers will stay in place when I remove the pins, so I should just need the mat and maybe new pins?
Also how does the paint hold up? Did you use normal spray paint or something else? I saw the mat from Ecklers was an ugly yellow color so if I order from them I would want to paint it too!
Does anybody have the chrome pins? I saw them for around $85, is it really worth it?
Old Jun 10, 2008 | 03:31 PM
PETKAH's Avatar
PETKAH
The retainers are somehow "glued" to the underside of the hood. I took the original pins cleaned up and painted silver - chrome is nice but the silver is fine. I just used regular black spray paint - of course wiped off grime and dirt. While you are there - paint the entire underside of the hood with black spray paint - take off latches, etc.-
most time consuming thing was masking out what didn't need to be painted - used an old sheet over the engine and radiator - taped newspapers to front of hood to avoid overspray. Really quite easy and really looks professional. (if you paint underside of hood make sure it is super clean as oil/etc over the years gets on it -just clean with degreaser then soap and water, rinse, dry you're ready to go.)
Old Jun 20, 2008 | 06:23 PM
77vetter's Avatar
77vetter
I got my mat this week and am going to install it this weekend. One side has something of a liner and the other side is like your basic raw insulation.
According to the way the mat is cut the side with the liner goes up against the hood. So my question is, can you spray paint the other side? Will it cause any issues if it is painted? Seems like it would not perform as designed if it was painted
Old Jun 20, 2008 | 07:16 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
For years I kept cleaning, fixing, gluing, fussing with and replacing my hood liner on my '75 vert. It wasn't until I found out the purpose of the liner was to "surpress" the engine noise....I thought it protected the hood's paint. Think about all the C3's w/o the hood liners....1968-1973...that the paint was fine. Anyway, I removed it, and had a local body shop sand, clean and paint the underside of my hood...they didn't use any kind of engine heat paint....just regular automobile enamel with clear coat....the blue flames were an after thought.
I've had it off for the past year and I drive it everyday with no problems whatsoever. You may want to investigate your doing the same... I wished I had done that sooner!
Old Jun 20, 2008 | 07:30 PM
77vetter's Avatar
77vetter
That is I love the look! I always thought it was there to protect the hood/paint from engine heat. I will definitely look into getting the hood painted - I might copy your flames too if thats ok, I really like the look!
Old Jun 20, 2008 | 08:50 PM
vetteguy75's Avatar
vetteguy75
Go for it!!!
Old Jun 20, 2008 | 09:56 PM
randommj's Avatar
randommj
I took mine off, has to be one of the better weekends I put on the vette, its made the engine bay look infinatly better after I painted the underside of the hood flat black
Miles
To Hood insulation installation
