Tach. options
Old Jun 11, 2008 | 10:33 PM
Am4wag's Avatar
Am4wag
Default Tach. options
Got an HEI with the original tach. cable laying beside it/so no tach.What are my options to have a tach.?
Old Jun 11, 2008 | 11:25 PM
Durango_Boy's Avatar
Durango_Boy
Take a sec please and fill out your profile so we know things like what year your Vette is.
Also, can you explain better what you're asking? Are you meaning someone replaced your tach drive distributor with an HEI that uses a wire for an electric tach, yet you still have the mechanical one?
The only option I know of is to either convert to an electric tach, or replace that HEI with an HEI modified with a cable drive.
I'm not even sure you can still get them, but they were available and pricey.
Old Jun 11, 2008 | 11:55 PM
Am4wag's Avatar
Am4wag
Sorry.......it's a '74 w/350.Got the original tach. in dash.Yes,someone put an HEI in it that has provision for electric tach. on the cap.
Old Jun 12, 2008 | 12:12 AM
vadmkat's Avatar
vadmkat
Cruising
I just replaced the distributor in my 350 '69 - it's also got a mechanical tach. I got the distributor from Summit racing, fits perfectly, works extremely well - and it's an HEI. Just call them up, tell them you want a mechanically driven distributor for your tach, and they'll set you up. I think mine was around $250.
Old Jun 12, 2008 | 01:47 AM
chvet73's Avatar
chvet73
I got a factory electronic tach from a later model C3. I think it's a '76. Fits right in, matches well. But most of all it works just fine. I would do it again.
Old Jun 12, 2008 | 05:59 AM
Gordonm's Avatar
Gordonm
I had my 72 mechanical tach converted to electronic. Works much smoother and no cable for the tach drive anymore.
To Tach. options
