Fast Idle
Old Jun 12, 2008 | 02:35 PM
nichboy's Avatar
nichboy
Default Fast Idle
My 82 when cold idles real high, even after 10 minutes of warm up. When put into gear rear end makes a loud thunk noise. After driving and warmed up everything is fine. Is this normal?
Old Jun 12, 2008 | 04:44 PM
ROBMERRILL's Avatar
ROBMERRILL
How high is high? Should be around 700rpms but most cross-fires are around 800-900rpms. You probably have a vaccum leak that is causing the high rpms.
Old Jun 12, 2008 | 09:39 PM
dannyman's Avatar
dannyman
No, it is not normal. How high is your idle rpm?
Old Jun 12, 2008 | 09:45 PM
wiseman79's Avatar
wiseman79
Is it still CF or carb?
Old Jun 12, 2008 | 09:49 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
sounds like a vacuum leak to me
Old Jun 12, 2008 | 11:05 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Try this site. http://www.crossfire.homeip.net/index.php? These guys will help you with crossfire questions.
Old Jun 13, 2008 | 08:44 AM
nichboy's Avatar
nichboy
Where and how would i start looking for a vacuum leak.
Old Jun 13, 2008 | 10:25 AM
crossfire1982's Avatar
crossfire1982
High idle is a common crossfire problem and it can be time consuming to track down. The link that shaggyvette posted is a great resource. The guys, and girls there live, eat, and breathe crossfire injection. You will need to join the forum to view the articles but joining is free. What is the high idle before it settles down and what rpm when it does settle down.
To Fast Idle
