78 water temp question
Old Jun 18, 2008 | 01:36 PM
martinjp's Avatar
martinjp
Default 78 water temp question
What temp should a 78 L-48 run. Obviously different thermostats will allow different opening temps, but what is normal for this era corvette? The car I am looking at runs just over 200 deg. Sounds a little high to me. My other vettes 68-72 have always stayed around 175. Your thoughts???
Old Jun 18, 2008 | 02:09 PM
fauxrs2's Avatar
fauxrs2
my 78 runs a 190 deg thermostat and runs pretty much right at 190 regardless of conditions. I have a cheap replacement radiator and a clutch fan.
Old Jun 18, 2008 | 02:20 PM
Ironcross's Avatar
Ironcross
computerized Vettes with heavy emissions burdons run hotter than a early model. 195 thermostat is also necessary to accomplish this in States where the requirements are enforced. If in Michigan, your home free with anything. A fender or bumper could be falling or in danger of falling off and it would still be roadworthy here. The State is run by Democrats,,,
Old Jun 18, 2008 | 03:45 PM
wildchris's Avatar
wildchris
Mine is a L82 it runs@185deg climbs to 195deg in 4th at 3,000rpm and up never hits 200. I just whent all the way to Providence and back about 80miles on saturday and it was like 85deg. I was a little nervous because I has not taken it on a long trip like that but it never hit 200deg.
Old Jun 18, 2008 | 04:00 PM
rayluka's Avatar
rayluka
My 76 runs at 190 all day. I was told you can put a lower temp thermostat in. It will open earlier and allow for more cooling
Old Jun 18, 2008 | 04:24 PM
fauxrs2's Avatar
fauxrs2
nothing computerised about a 78 though...theres no reason he shouldnt be able to cruise all day at 180-190 depending on the thermostat he runs
Old Jun 18, 2008 | 06:24 PM
65GGvert's Avatar
65GGvert
My 78 runs 165 in cool weather. On a hot day with the air on, it will climb to a touch over 200. Don't know how accurate that analog gauge is, but it's pretty consistent. On a hot day with the air off, it's around 185 or so.
Old Jun 18, 2008 | 06:51 PM
Fay vette's Avatar
Fay vette
My 77 runs 160 during normal driving and to 180 on hard runs. Not sure what thermostat but 160 if I had to guess.
Old Jun 18, 2008 | 07:00 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
My 80 L48 Auto runs at around 190 with the A/C off.....with the A/C on its a little over 200
To 78 water temp question
