brake vacuum source
Old Jun 21, 2008 | 12:51 AM
temvette72's Avatar
temvette72
Default brake vacuum source
I am putting a holley spreadbore replacement on my Vette. Can I use a vacuum port that is on the manifold, or do I have to use the source on the back of the baseplate of the carb? The new carb has a block-off screw in the port at the rear, and I have heard it is difficult to remove. Thanks!
Temvette72
Old Jun 21, 2008 | 01:10 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default spreadbore installation
I installed the spreadbore 6210 double pumpers on my 68 and 70 way back in 1974 and still in use on the 68. No power brakes on the 68, but the 70's source of vacuum for the power brakes was not changed, continued with the source from the fitting in the intake behind the Holley.
Use full time vacuum port for your vacuum advance, leave the ported vacuum source capped and not used.
Old Jun 21, 2008 | 11:28 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I just installed a Holley 4175 spreadbore Q Jet replacement. The vac port for the booster is in the base plate with 1/4" pipe thread. I found a hose nipple adapter for 3/8" hose at advance auto parts that solved the issue with a [piece of 3/8" fuel line. I also used 3/8" steel fuel line for part of the length. The block off port should not be difficult to remove if the carb is off the car. If the carb is installed, take it off to swap the plug out for a hose adapter.
Check out this photo and see if it looks the same as yours.
Old Jun 21, 2008 | 05:22 PM
temvette72's Avatar
temvette72
Thanks for the replies. My intake has a vacuum outlet on the back (between the carb and the distributor). It has three ports, one which is unused and capped. I just plumbed the brake booster vacuum right to the unused port, and it works fine.
temvette72
To brake vacuum source
