I have a 78, engine is cold, not running. Oil pressure is reading 40. When at idle (at stop light, etc) it reads higher. When cursing, it will read at close to 80. It was doing this before I changed the oil. I changed the oil on 6/20/08.
Should the gauge show any pressure when not running?
If the answer is no, can the gauge be calibrated, if how?
