Weld wheels on Corvette?
Old Jun 22, 2008 | 11:29 PM
Highhat's Avatar
Highhat
Default Weld wheels on Corvette?
Has anyone adapted 15 x 8 Weld rims on a C-3?
I have a pair to try with 4.25" bp, but the hub centric hole is too large (3.25" as opposed to 2.75"), need additional 7/16" spacer to clear the caliper, and need to install longer wheel studs.
Great to hear from some one who has done it already. Thanks
Old Jun 23, 2008 | 08:21 AM
The Money Pit's Avatar
The Money Pit
Draglites on my 80. Check out my website for details.
Old Jun 23, 2008 | 10:41 AM
Highhat's Avatar
Highhat
Great info. Thanks.
Did you use a hub centric adapter, for I assume that the Weld hold was larger than the stock hub centric?
Old Jun 23, 2008 | 01:41 PM
The Money Pit
Yes the rear VB&P adaptor is hub centric, the front spacer is not.
Old Jun 23, 2008 | 02:48 PM
ajrothm's Avatar
ajrothm
FYI:
Thunder Racing sells some billet wheel spacers that are stud/lug centric. Not like those old Mr Gasket spacers with the huge holes that the lug nuts would just fall through. These actually fit tight on the studs, then you can use your regular acorn style or deep lugs(for lug centric wheels).
I ran into this problem when I put Z06 wheels on my T/a and the offset was way off. So I tried all the usual spacers and continued to get a wobble in the steering wheel. Once I found these spacers, I slapped em in and its perfect. Smooth as a stocker. I did use long ARP 220k psi studs though.
The spacers are balanced and precision machined.....About $100 for all 4 I believe it was.
Old Jun 23, 2008 | 08:32 PM
CorvetteDave01's Avatar
CorvetteDave01
I have Weld XP's on mine. Don't think they are made anymore unfortunately. 15X8X3.5" bs front with 235 60's. 15X9X5.5"bs back with 295 50's (with 5/16" spacer in back).
Have 1/2" shorter spring each side and offset trailing arms too.
Old Jun 25, 2008 | 01:38 AM
Frank_833's Avatar
Frank_833
I had some spacers made that were lug centric and hub centric. These are flat (9mm or 12mm thick) so do not go into the wheels. I did install longer studs.
I got the spacers from some on eBay, but don't remember who. Something like $60 for the set of 4.
Old Jun 25, 2008 | 07:36 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I run Weld Draglites in the rear with no spacers.. However, I do have Aerospace brakes and with those brakes, no spacers are needed
Old Jun 28, 2008 | 11:47 PM
Highhat's Avatar
Highhat
Anyone know of source of longer 7/16" studs that fit.
Old Jun 29, 2008 | 12:56 PM
Highhat's Avatar
Highhat
Nevermind (dont you love answering your own questions)
Moser 7/16"-20 x 2 7/8" .480" knurl
Mr. Gasket 4310G 7/16''-20 Wheel Studs .480'' Knurl
Old Jul 15, 2008 | 12:24 AM
Highhat's Avatar
Highhat
Got them to fit, with front skinnies. Here they are:
Old Jul 15, 2008 | 09:02 AM
J.K. Cooley's Avatar
J.K. Cooley
Looks good Highhat......
Old Jul 15, 2008 | 09:35 AM
Highhat's Avatar
Highhat
Ditto!
Old Jul 28, 2008 | 08:58 PM
AimHigh's Avatar
AimHigh
I run 15 x 8 with 1/4 spacers and they work fine
To Weld wheels on Corvette?
