Window regulator gear...repair or replace
Old Jun 24, 2008 | 08:20 AM
seventysixvette's Avatar
seventysixvette
Default Window regulator gear...repair or replace
It always seems to happen, doesn't it? I start to change over to different door glass just to find out the electric window hardware is ruined.
Has anyone used the repair end gear (it bolts against the old teeth) for their electric window regulator, instead of replacing the whole arm?
My motor gears need replaced, Wilcox has a good price on those, but the large gear on the arm is damaged also. It looks like the bolt on replacment would be easier to use if it works ok.....anyone ever use 'em?
John
Old Jun 24, 2008 | 08:33 AM
80Vette80's Avatar
80Vette80
I have the same problem. I just bought the bolt on, but I have not installed yet... I will advise.
Old Jun 24, 2008 | 08:35 AM
SIXFOOTER's Avatar
SIXFOOTER
I put on a set for a friend once, its actually More work, not less since you have to take the thing out and put it back in in addition to fitting the gear. I replaced the entire arm on both of my own cars. Personally I wouldn't use the kit again unless $ is an issue
Old Jun 24, 2008 | 09:31 PM
terry82's Avatar
terry82
i did it on my 82 over six years ago .window still works good .
Old Jun 24, 2008 | 11:25 PM
seventysixvette
Guys, thanks for the answers. It helps when figuring out what to do.
John
Old Jun 25, 2008 | 08:56 AM
moosie982's Avatar
moosie982
I used the gear repair piece, it works fine. Peace,,, Moosie
To Window regulator gear...repair or replace
