sticky door
Old Jun 25, 2008 | 11:44 AM
cab's Avatar
cab
Default sticky door
my driver side door is hard to open. i have to give it a good tug to open it. could this be a adjustment problem inside the door panel? i dont believe it is hangin on the stricker i have moved it several times and it does no good.
Old Jun 25, 2008 | 02:59 PM
temvette72's Avatar
temvette72
There is a rod between the "flapper" ouside door handle and the latch mechanism inside the door. You can adjust the length of this rod to actuate the latch mechanism. Unfortunately, it is inside the door and one must have small hands and infinite patience (of which I have neither!). Good luck!
Temvette72
