Intake date code
Old Jun 26, 2008 | 11:39 AM
r0t0rdr1ver's Avatar
r0t0rdr1ver
Default Intake date code
Can anyone help with the location of the date code for a 3937797 427 intake? Thanks.
Old Jun 26, 2008 | 11:59 AM
schmegeggie's Avatar
schmegeggie
This is from my early 69 SB 350, but it should be just above it, to the left.
J = October
26 = 26th
8 = 1968
Old Jun 26, 2008 | 12:03 PM
halfmoontrail's Avatar
halfmoontrail
If that is 435 hp tripower aluminum, I think the date code is underneath, and under the heat shield (riveted on) -- Not apparent, not judged.
Steve
Old Jun 26, 2008 | 12:07 PM
r0t0rdr1ver
Hmmmm, I had a look, but I don't think it's in the same spot as your intake. Thanks for the help.
Old Jun 26, 2008 | 12:10 PM
r0t0rdr1ver
Steve
That's what I thought...thanks for the confirmation!
Are there any date codes on the carbs? How are they shown?
Old Jun 26, 2008 | 12:24 PM
halfmoontrail
May I suggest that you buy the NCRS Technical Information and judging guide, full of information and cheap (you don't have to join NCRS to buy it).
Carbs have stamped codes, I think on fuel bowl or main body, apparent when installed. First set of numbers is use code, second set is date codes. 3 digits on originals, I think it is 2-digit month, last digit year. If 4-digit date codes, they are later replacements (~'70+), I think first 3-digits are julian day, fourth digit is year.
Steve
To Intake date code
