fixing fiberglass
Old Jun 27, 2008 | 12:39 PM
itslaf's Avatar
itslaf
Default fixing fiberglass
whats the best way to fix fiber glass that isnt going to cost a fortune and is quick and somewhat easy to do. b/c on my 78 where the antenna is at the guy that i bought it off of switched it to the other side so now theres a hole where the antenna used to be. and on the front it looks like the fiberglass started to peel up. any suggestions?
thanks
Old Jun 28, 2008 | 08:21 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Glass is easy to fix, but scary...
You gotta feather the edges of the hole so it's nice and big this it so the glass mat has something to bond to, then fill the hole with fiberglass mat ( use the non woven stuff ) , build it up till it's almost level with the body.
Use short strand filler to finish it up, then prime sand and paint as usual
Keith
Old Jun 28, 2008 | 12:10 PM
itslaf's Avatar
itslaf
alright ill try that thanks
Old Jun 28, 2008 | 12:29 PM
wolfemc's Avatar
wolfemc
Default Correct the location
my suggestion is to put the antenna back in the right place while you're doing your repairs and patch the other hole that the previous owner drilled.
How do you best "feather the edges of the hole", 427V8? Is there a tool (rasp) that is best to use?
Old Jun 28, 2008 | 01:22 PM
nutsy's Avatar
nutsy
a dremmel should work great th feather edges.
Old Jun 28, 2008 | 06:13 PM
427V8's Avatar
427V8
I use a 4" grinder, it makes alot of hole very fast
Old Jun 29, 2008 | 12:31 AM
GPGG70's Avatar
GPGG70
thanks
I bought the fiberglass repair DVD Vol 1 & 2 from ecklers and once i get to that point in my restoration I will have no problem doing a couple of glass repairs to the car based on what I learned from the DVD's.
To fixing fiberglass
