Paint the vette.....
So......curiosity makes me ask this question. Can someone with no experience in painting (Full scale) cars, (I can paint the hell out a Revell) actually paint their own car? I have seen many posts about the MANY hours of sanding and tacking, and sanding. Was amazed bu the gentleman that painted his car with aerosol paint...Rustoleum, was it? While I don't believe I would go that route, I am just testing the waters. I know my way around an engine compartment, and general auto knowledge. But never any body work.
When it comes down to it, is it worth it. I have been to 4 different shops and have got $4300 - $8500. I told each guy that I was looking for a nice paint job...but no need for a "Show Car" paint job. Any and all advise is welcome. Time is no issue. I have plenty. Just don't ....really...want to dump the same amount into a paint job, that I paid for the car in t he first place. But, of course, don't want to hack it up. Can it be done?
im 16 and have a few jobs under my belt. its easy when you have some one who knows what there doing help you on your first one. after that it was easy for me. i just soaked up all the knowledge i could.
you can save a lot of money by sanding the car your self (not hard) and doing the color sanding your self. that's what i think you should do if the price is right. you could also primer it your self with out too much headache, i find it hard to mess up when shooting primer. ive never had it run. then have maco shoot the color and clear coat. normaly i would say stay away from them but thats because of there crappy prep work but if you do it like i said then all the prep work would be done so they cant messit up that bad.
I had about $100 in the paint and clear (already owned an air sprayer, respirator, and everything else I need). I figured for the money why not give it a try, if I wasn't happy with it I could always still take it to a shop. Fortunately it worked out (after I sanded the junk paint off and repainted it with the Napa paint) and I'd do it again without nearly as much hesitation.
Check out the thread if you want, it's kind of an interesting read - you can see how I went from having no idea what I was doing to being confident enough to paint the whole car, and how the type of paint made all the difference in the world.
http://forums.corvetteforum.com/show....php?t=1991892
I say if you want to try it, go right ahead. Eveyone has to start someplace including proffesionals.
Do your research ,ask for advice from people you can trust(this is a great place for that), and proceed from there.
You may be surprised at the good results you may get in the end
And in the event you arent happy with your progress or decide it isnt for you, you can send the car to a shop then...
The biggest problem is(besides making sure the prep is perfect) is setting up a make-shift booth that will ventilate while keeping dust and bugs out.
I was lucky back in the late 80's when I was in high school to have the opportunity to spend three periods a day doing body work/paint and get credit for it. Painted lots of cars and did lots of sanding and prepping. Painting the car is not going to be the challenge, its getting the car ready to paint that will be.
etc., So I figure I'll start there and see how I do. Quote: The biggest problem is(besides making sure the prep is perfect) is setting up a make-shift booth that will ventilate while keeping dust and bugs out.
Thanks Bruthish! I was just about to ask on the importance of the tent/ventilation. I share a 2.5 stall with my wife and her new Tahoe. Obviously don't need to elaborate what would happen to me Sex life if I spoojed on the wifes Tahoe.
Can I partition the garage with a tarp? I am installing a garage heater (Gas) this Summer (for my Vette of course) and know that I have to have a vent or two for that. Should I add two vents on my side of the garage and get a fan set up for increased ventilation? Or am I way off here?
When you say "needs no body work", what exactly does that mean? my car has no dents or holes, not even any noticeable door dings or anything, and i looked. is there some other 'body work' that lurks under the paint?
$200 worth of adhesive, fiberglas products, 'bondo", and sandpaper to do the bodywork. It looks darn good for the minimal investment. Plus, it only took them a week and one day to turn it around.
Temvette72
Last edited by Michigan Vette Guy; Jun 27, 2008 at 11:17 PM. Reason: Changed a letter from small case to large case.
It took about two hours to do that (you wouldn't think it would take that long, but going up and down the step ladder, moving it, stapling everything to the ceiling the time just went by). For ventilation basically what I did was shut the garage leaving about a foot or so crack at the bottom, set up a couple of fans blowing outward to the driveway, and then dropped another sheet of plastic in the back all the way to the floor, taped at the seams, and cut out around where the fans were, taping the plastic to the edge of the fan so the only exit for the air was through the fans and nothing was coming in. You can't tell from this pic, but my entrance/exit to the booth was due to a double-lined right side (I would walk between the two sheets to get out). With the fans going it sucked all of the fumes out, my wife complained non-stop when I did just the hood (you can see the "little" masked off area in an earlier pic before I did the whole garage) because of the fumes going upstairs, but when I did it the second time with the fans sucking everything out she said she never smelled it.
Get a good respirator too, not just those little cotton/paper things that just covers your nose and mouth with a little strap. You want something with a rubber nose/mouth surround with the cartridge on each side. Harbor Freight has them pretty cheap if you don't know of anywhere to get one locally. That makes all the difference in the world, when I started I just used the little mask and ended up with both a headache and raspy voice for a couple of days. Second time around I used the respirator and I couldn't even smell it.
Learn from my mistake!
Also ... do it during the day so you're less likely to have bugs land in the paint.
I've done it this (wrong way) plenty of times myself w/ house fans (4) and have been lucky. I regulate the amount of buildup of fumes though, let them evacuate, then continue, and paint piecemeal because the lack of a pro setup.
Also you'll need to ground the car by hanging a chain from the axle to the floor,(not on plastic), and wet that area a bit for insurance.
Since this would be your first time painting, what I would suggest is doing it piecemeal, ie: front fenders, hood, then later doors and rear. I've heard that the rear window area is a tough spot but haven't painted a vette yet myself.
The L88 scoops were a bit tricky for me in the past but I can shoot them good now. Painting piecemeal you won't have so much buildup of fumes and can take your time, and get a better job should something go wrong (which it most likely will). Have some large cardboard pieces handy beforehand and adjust your gun on that before shooting the car.
If you get a run during paint, leave it alone, you can most likely sand it out once dry, trying to fix it wet will cause you a major headache.
Not everyone can shoot paint, there is some talent involved. Good luck.
As far as venting, I like Ron R's set up, and could get away with that with the Wife. Thanks again for the tips on the grounding the car, the cardboard spray for adjustment, the "Don't try to correct when wet" tips...all great!
Just trying to give you any helpfull advice I can, I learned a lot here myself also and will use that info next time I pick up a spray gun. So far I've never removed any body parts before paint.
Pollen and bugs are the hardest thing to keep out unless you build a filter system. I had 3 outgoing fans and one incomming at the opposite end of the garage in a window w/screen. Definatly take Rons advice on the respirator, base coat/clear coat I've heard is very toxic. Never used it yet but will be soon enough. Post pics if you decide to DIY.
Edit: The Rustoleum paint job mentioned was done by LowBuck w/ foam rollers I believe, he did an outstanding job and changed my mind that it couldn't be done and look good.
I am looking for the easiest
No, bad word. The most cost effective, keeping quality in mind. I am assuming many hours of sanding and prep. Is it best to use a block with the sandpaper? Or have any of the resourceful Vette heads out there constructed any sanding devices to help ease things. I am also assuming you don't use any kind of a power sander? A lot of questions here. But I'm trying to soak up as much heads up knowledge that I can before starting.
I've yet to hear of it being chemically removed, I would assume it may degrade the fiberglass?, I'm NOT the expert to ask on that.
A painting search here should reveal a lot you need to know.
As for any type of homemade tools to use, I used a 1" and 1-1/2" thick x 8" long piece of PVC wrapped in that foam water line wrap to mold in the last L88 scoop I did on a non vette wrapped in different types of sandpapers. Used it at 45% angles up and down the length of the scoop where it met the hood and then around to the front. It worked good and would think it would do OK with some other areas possibly. Thats about all I can offer.
