Knock Sensor Connector
Old Jun 29, 2008 | 09:02 AM
mrlucio79's Avatar
mrlucio79
8th Gear
Default Knock Sensor Connector
The knock sensor just forward of the starter had a disconnected wire. I looked at the connector and it looked all rotted and now the wire will not stay on the knock sensor. Is there a easy fix for this or do i have to replace the wiring harness. Your help is apprecaited.
Old Jun 29, 2008 | 09:18 AM
guappy's Avatar
guappy
You don't say what year the car is but you should be able to get a connector end at the nearest GM parts because they should have the connectors or be able to order you one, yours is not the first one to break from the heat.I hope this helps.
