Freekin ANTS!!!!!
Old Jul 2, 2008 | 02:57 PM
justaguy10825's Avatar
justaguy10825
Default Freekin ANTS!!!!!
Anyone know a good way to rid a car of ants? There is no food in the car but it was parked for a while & they moved in anyway... HELP
Old Jul 2, 2008 | 04:21 PM
mdbelanger's Avatar
mdbelanger
Bug Bomb. Yet you'll have little bodies all over the place. If your want to have then move out and arn't in a rush. Park your car in the hot sun and run a dehumiditifier in the car. Ants need moisture to nest.
I have done this in campers and houses that have had ant problems.
If you have ants in your house, most likely you have rotten wet wood someware.
Michael.
Old Jul 2, 2008 | 05:35 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I was told to use bounce dryer sheets, give it a try
Old Jul 2, 2008 | 06:38 PM
jim2527's Avatar
jim2527
Ants dislike water and heat.
Leave your windows off and tops off on a sunny day. Ants leave behind a scent that they use for 'directions'. Sweep where you park your car everyday to disturb the scent trail. If you think about it, ants only access to your car where the tires meet the ground. Because ants live in and like social structure any prolonged disturbance will cause the colony to move.
Old Jul 2, 2008 | 07:10 PM
alanbl's Avatar
alanbl
You need to get one of these. I believe that Summit carries them.
Old Jul 2, 2008 | 11:35 PM
BigEarl's Avatar
BigEarl
I just got rid of some ants at my house. So im all read up on ants. Depending on what type of ants you have, you may not want to use any sprays. It stresses them out and then one nest splits into 2 or 3. Get some Terro liquid ant killer from Lowes or Home depot. They will eat it, bring it back to the nest and feed the rest of them.
Old Jul 3, 2008 | 09:36 AM
blunblk68's Avatar
blunblk68
can you say shop vac!! suck them suckers out!!
Old Jul 3, 2008 | 01:55 PM
??????'s Avatar
12 gauge ?????????
Grant
Old Jul 3, 2008 | 02:03 PM
onaqwst's Avatar
onaqwst
magnifying glass.... and some beverages
Old Jul 3, 2008 | 03:19 PM
BarryK's Avatar
BarryK
not true about the water.......
I had a majotr ant problem here at the house for a while and nothing we did would get rid of them.
I finally found their nest. actually, found 3 or 4 separate nests with the main Queen ant from each nest and all their eggs.
Guess where it was........... in the hottub that broke a couple years back and is still on my back deck. The hottub still had a few inches of water in the bottom and the cover on it creating a very warm, very wet and humid environment for them to thrive in. They made themselves at home real well in there
A couple applications of commercial ant killer took care of that problem and they haven't been back since.
Old Jul 3, 2008 | 03:26 PM
BarryK's Avatar
BarryK
justaguy
getting rid of the ants in the car is not going to be fun or easy I hate to say.
with the experience I've had with ants you probably have one of two problems here:
1. there is SOMETHING in the car attracting them as a food source. You said the car was parked for a while and that could easily mean there was a mice nest in there and perhaps one died and the ants are feeding off it. When I bought my '78 it had sat for a few years and I found three different mice nests throughout the car.
Find the source of the food the ants are going for and you will get rid of the ants.
2. the ants may have set up a nest in the car. If that's the case you have a bigger problem because unless you find the nest you will never get rid of them. it could be anywhere - under the carpet, inside a seat, under the dash, under a piece of interior molding, in the frame, anywhere.
if there is an actual nest in the car you need to kill the entire nest, including the Queen ant and all of the eggs. You kill the queen and the eggs and the worker ants will go elsewhere.
Old Jul 3, 2008 | 03:36 PM
jds68stang's Avatar
jds68stang
Diatomaceous Earth, sprinkle some of that around and its like coating them w/ fine glass, cuts them up, they dehydrate and die off. Then you can vacuum it up, its non toxic.
EDIT:
This is what I made to blast the bugs w/ in larger areas, and the yard, it works great, we have small dogs to protect and not poison, they can walk thru it and its not harmfull. It kills fleas, ants, ect... . It does build a large cloud outdoors doing a yard, thats one drawback, but less if the blower speed can be slowed down, still working on that solution. For small areas put some in a salt shaker or the like and sprinkle it around, when the ants walk thru it their as good as dead.
The stuff is a bit cakey so you have to tap the container periodically if you make one of these.
Old Jul 3, 2008 | 03:42 PM
justaguy10825
Thanks for all the suggestions.... I'm thinking gas, a match and a call to the insurance company...LOL..... Little bast@#$%
Old Jul 3, 2008 | 04:01 PM
snapshot's Avatar
snapshot
3 parts powdered sugar, 1 part borax. The powdered sugar attracts them and then the borax kills the nest. Also bleach will destroy their scent trails.
Old Jul 3, 2008 | 05:05 PM
Red 69's Avatar
Red 69
This stuff works great and the small bottle only costs $1.98. I use it regularly here in FL and boric acid on aunt hills makes fast work of them. The boric acid is sold at Dollar Stores for guess how much, yup a buck! It is sold as ant and roach killer in yellow plastic squeeze bottles.
Old Jul 3, 2008 | 06:03 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Lay a potato chip on the floor and vacuum it up as they come out. Got rid of them in my house like that, didn't want to spray any poisons.
Old Jul 3, 2008 | 11:29 PM
jrl77's Avatar
jrl77
A gallon of gas and a book of matches ! It works all the time !
OR
Sell me your car I will pay you double what the exterminator charges me . I promise
To Freekin ANTS!!!!!
Old Jul 3, 2008 | 11:47 PM
Yobi1Kanobi's Avatar
Yobi1Kanobi
i got ants too.. dam rainy season.
Old Jul 4, 2008 | 04:55 AM
stingr69's Avatar
stingr69
Terro is great. The kind I have used is a syrup that you put on a scrap of cardboard and put it where the ants can find it. They will swarm to it for a day or so then you don't see them anymore.
-Mark.
Old Jul 4, 2008 | 12:41 PM
Project80's Avatar
Project80
EDIT:
Didn't we see this on Caddy Shack?
