Brighter headlights
Old Jul 3, 2008 | 03:21 PM
Reignman's Avatar
Reignman
Default Brighter headlights
Hi, can anyone help me find brighter headlights than sylvania's regular stuff found in autozone or checkers? I got used to using my mom's car and now it feels like I cant see anything in my 76. The lamps do not need replacing because I changed them around a month ago. Any advice is welcome.
Old Jul 3, 2008 | 04:03 PM
Scott Marzahl's Avatar
Scott Marzahl
Use the advanced search function, lots of good stored info, you should also add two relays for the headlights and larger gauge wiring while you are at it.
http://forums.corvetteforum.com/show...ter+headlights
Old Jul 3, 2008 | 06:22 PM
SteveG75's Avatar
SteveG75
I added two relays controlled by my headlight switch and then wired the lights through them directly to the alternator. Much less voltage drop and brighter bulbs.
To Brighter headlights
