Neutral Safety Switch
Jul 13, 2008 | 02:07 PM
2nd Gear
hi, can someone please tell me where the neutral safety switch is located on a 1974 corvette? thank u.
Jul 13, 2008 | 02:20 PM
It should be located high up on the clutch pedal arm, up under the dash.
Jul 13, 2008 | 03:25 PM
I thought is was attached to the transmission.
In an automatic it is on the shifter, only accessible by removing the shifter/temp control plate and/or the whole console.
In an manual it is on the linkage in some form and potentially can be changed under the car.
Jul 13, 2008 | 07:59 PM
Not sure about yours, but on my 81 its under the console by the end of the shifter lever. Kind of U shaped.
Jul 13, 2008 | 09:10 PM
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Automatic NSS (& back up light switch) is attached to the shifter under the center console.
On a manual, it is attached to the clutch pedal.
Jul 13, 2008 | 09:16 PM
There is no 'neutral safety switch' on a manual transmission car.
Jul 13, 2008 | 09:33 PM
Jul 13, 2008 | 09:34 PM
Quote:
Originally Posted by
wfo76
The clutch safety switch does get referred to as the neutral safety switch,even some of the wiring diagrams call it a NSS.Dont like it much myself.
Jul 13, 2008 | 09:49 PM
DWncchs
I just replaced the harness on mine and its mounted under the dash on the clutch pedal assembly
Jul 13, 2008 | 09:52 PM
2nd Gear
neutral safety swich
thanks guys, i appreciate the help
