AC Compressor Question
Old Jul 15, 2008 | 05:04 PM
hamsteria's Avatar
hamsteria
Default AC Compressor Question
My vette is a 78 and the AC compressor doesn't even kick on. When I used a jumper wire on the low pressure switch (that I learned on this forum!), it kicked right on. I can feel cool, not cold, air blowing out.
Does this mean that the compressor is actually ok and it only needs charged? If so, should I have it converted to R34?
Thank you again.
Brian
Old Jul 15, 2008 | 05:27 PM
hamsteria's Avatar
hamsteria
I guess I mean R134. Not R34.
Old Jul 15, 2008 | 05:41 PM
OogieBoogie's Avatar
OogieBoogie
The fact that the compressor kicked on means that the compressor is fine. I would have the system pressure checked to make sure that you don't have a clogged orifice tube. If the system is indeed empty, have it accumulator evacuated and then retrofit the system and fill with R134a.
Old Jul 15, 2008 | 06:05 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
If the compressor kicked on it doesnt mean that its OK, it only means the clutch is engaging. If that system was down for a long period of time, I would (at least) get the system fully flushed, changed all the O-rings, get it retrofitted with R134a then change the orifice filter. Make sure you do a vacuum discharge for at least 30 min before charging with R134a.
Old Jul 15, 2008 | 06:08 PM
AimHigh's Avatar
AimHigh
If the comp comes on then you probably have a bad low pressure switch or,,,,as in my case the connection was bad.
Old Jul 16, 2008 | 12:26 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
To AC Compressor Question
