Last night I went out to start up my 69-350 and when it started , it started to rain oil all over the windshield, I dont have hood on, took a look and the oil pressure line at the block had broke and was shooting oil all over,who makes a oil line kit for a small block vette, THANKS FOR ANY INFO, my oil pressure gauge is fine, just need a oil pressure line kit.
If the oil line broke at the fitting were it goes into the block and the rest of the line looks good you can just get a new compression fitting and reuse the line.You should be able to get oil line kit at most any auto parts store.
Thanks for info,that is what I was thinking ,just making sure--
You can do that. But I think the "line" is telling you something. You can get a new line and fittings at one of the chain auto stores. I think it is by sun pro. I had the same problem on my 73 but mine was at the gauge side. Can you say carpet replace? I put a later electric gauge in this will never happen again
Thanks Artsvette73, I got a new line and fittings today
