Electric Fans for C3
Old Jul 20, 2008 | 05:52 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Originally Posted by Durango_boy
All engines and cooling systems are unique and different from one another but I would say around 200 - 210 is safe under those conditions. Anywhere above 180 is good for engine operation, and under 220.
Well I don't disagree w/keeping it about 200. However when I first got my 84 C4 I was concerned as it would run up to 225 before the fan kicked in. Thought something was wrong but soon figured out that was normal, or at least the way it was designed. Guess GM wanted it to run hot for emission reasons. So apparently 225-230 is not an issue for a smallblock chevy. FWIW.
Old Jul 20, 2008 | 06:31 PM
Durango_Boy's Avatar
Durango_Boy
That's how most modern engines are built, and I guess it started with fuel injection systems. I see things on older engines start to cook at those higher temps.
Old Jul 20, 2008 | 06:32 PM
bucket's Avatar
bucket
Originally Posted by DVNTST8
Corvettes tend to ru hotter than other cars, especially C3s, 225 isn't overly hot, for these cars.
Now, that's different than in your Mustang or 78 Cutlass, for sure. But it's no seriously hot, for these cars.
Now, a couple of years ago, I put in a DeWitt's aluminum radiator, with the dual Spal electric fans, new hoses, and all new foam seals (Dr. Rebuild). My temps went from 220-230, down to never getting above 195 now.
My problem was the opposite of yours, I think, I was getting hot on the freeway. So I'm thinking my seals were letting air get around the rad, and also my lower hose was worn out.
"Corvettes tend to ru hotter than other cars, especially C3s, 225 isn't overly hot, for these cars."
And what kind of temperature would you expect if the C3 sat idling in a garage with the a/c on (without any additional tem reducing features such as electric fans, etc.)?
Old Jul 20, 2008 | 06:55 PM
BigBlockTank's Avatar
BigBlockTank
My 69 big block runs at 195* moving or sitting. I have a DeWitt's 2 row small block radiator (the car was a small block car) and I run a mid 90's Lincoln MarkVIII 2 speed fan. I use a corrosion inhibitor also. I live in constant temps of over 100 in the summer, Tucson, AZ.
I heard alot of CF members not like the Mark VIII fan, but the thing works fine for me in some fairly extreme conditions, nuff said. Tank
Old Jul 20, 2008 | 07:43 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I couldn't disagree more but you're not alone in that belief. The reality is, c1-C3 Corvettes ran no hotter than any other car. No other car has been rebuilt, modified, and/or restored more than corvettes. I am not a purest judge or anything like that but I think the farther away from stock we get, the more problems we have. My 1980 has the ALL the original equipment, functioning correctly, and with the stock copper radiator it has never gone over 180 with the AC on. The problem is US not the cars. We tinker and modify, with mismatch components and we're surprised when it runs different? Many times when someone calls with a cooling issue they start with "my car is bone stock" except the motor is bored .030 and I went with an aftermarket cam, Hei ignition without vacuum advance, high rise intake, and STOP! What part is still original?
Old Jul 20, 2008 | 09:42 PM
Kid Vette's Avatar
Kid Vette
Amen, bro!!
Old Jul 20, 2008 | 10:24 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
You make an excellent point, Tom.
Also, consider me an EXTREMELY satisfied customer!
Old Jul 20, 2008 | 10:34 PM
Durango_Boy
Me as well.
I love my DeWitt's radiator, and I tell everyone how it's changed my car and where to get one.
Old Jul 21, 2008 | 03:45 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I see engine over heating problem exactly as any other mechanical problem with your car. You need to catch the original "cause" of it first, and automatically everything else will be solved. If you have a radiator size which is not matched with the engine size/power, then installing bigger fans wont remedy the problem, though it will reduce the temps. Modifying the engines shouldnt be a problem, but mismatching the components are.
How much your engine will add heat to the coolant =< how much your radiator should dissipate heat from the coolant, as simple as that!
Old Jul 21, 2008 | 08:26 AM
bucket's Avatar
bucket
Here is a modification of a question I asked earlier:
What kind of maximum temperature should you expect to see on a '69 stock, correctly configured, 350/350 C3 idling with the a/c on, in an un-airconditioned garage during 90+ degree summer weather?
Old Jul 21, 2008 | 09:15 AM
nichboy's Avatar
nichboy
I have a 82 model that may need the FOAM RADIATOR AND HOOD SEALS replaced. Can these be bought as a kit and if so where. Also if anyone has a picture of these seals in place would be appreciated.
Thanks.
