Engine Suffix Code?
Old Jul 20, 2008 | 12:48 AM
Avenger1970's Avatar
Avenger1970
Default Engine Suffix Code?
Hello to all!
I would like to see if someone could lend some help. I've been trying to figure out the suffix code (PHA) on my block and can't seem to find it listed.
Casting #14093638
Code from front passenger side of block (deck pad) - K0106PHA
It's a 2 bolt main
One piece main seal
Has undrilled tower posts for roller cam spider
I have double checked the suffix code PHA to be sure that's what the block is stamped with and it is correct just can't find it listed anywhere.
If I have decoded the rest of it properly it's a Canadian block produced on Jan 6th. Just would like to know specifically what year it is and what it was originally used in.
I appreciate any help with this, thanks in advance!
Old Jul 20, 2008 | 10:07 PM
Tom73's Avatar
Tom73
Closest that I can find is DHA. That is an '81 305ci used in B and G bodies.
tom...
Old Jul 20, 2008 | 10:21 PM
dannyman's Avatar
dannyman
14093638 = 86-94 350
Would match a PHA which is an 88 truck 350, 195hp.
Double check PHH isn't PHA.
To Engine Suffix Code?
